Super glue/baking soda mixed together for temp repairs.
Discussion in 'Flatbed Trucking Forum' started by kurbski, Jul 5, 2018.
  1. kurbski
    kurbski Light Load Member
    284
    644
    Jul 6, 2008
    NE Florida
    Stumbled across several utube posts about mixing super glue and baking soda to make temporary repairs. I've never seen this prior and would consider it (depending on whats broke) to keep me rolling. Seems simple enough : prep surface, apply SG, then BS and it hardens immediately. Anyone repaired metal/plastic or anything else for quick temp repair?
  3. Dave_in_AZ
    372,161
    Anything other than JBWeld is heresy.
    kurbski Thanks this.
  4. CharlieK
    CharlieK Medium Load Member
    374
    4,454
    May 13, 2015
    Minnesota
    Isn't that the point of super glue on its own? It hardens immediately? Whats the point of the baking soda... unless its to put on your hands to make sure you don't get stuck =)
    Ruthless, kurbski and Bakerman Thank this.
  5. homeskillet
    homeskillet Road Train Member
    5,684
    41,317
    Jun 1, 2013
    Dayton, OH
    QuickSteel epoxy, that stuff that comes in a cylinder....has a grey outer layer and a white inner layer. You can drill and tap it when it hardens, if need be.
    Snailexpress and kurbski Thank this.
  6. kurbski
    284
    644
    Jul 6, 2008
    NE Florida
    CharlieK, dont try this and get either one on your skin. if you decide to watch utube, it shows baking soda being added to a small wet puddle of super glue and hardens it up instantly. SG/BS is cheap and common item. JB weld and 2 part epoxy seems much better. Any port in a storm so they say....
  7. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Did that trick back in my r/c car days. Could use it on your dash or other plastic to repair cracks etc. Quicker and cleaner than two part epoxy
    homeskillet Thanks this.
