super single tires
Discussion in 'Questions From New Drivers' started by ACH1130, Mar 12, 2011.
  1. ACH1130
    ACH1130 Road Train Member
    2,695
    824
    Jan 23, 2011
    Land of far far away,
    seen quite a bit of them lately, when i was at fedex ground, i saw the converter dollies were all single tire, and a few of our trailers. Also notice that all of NFI's trucks an trailers have them, is there n e pros and cons to them?
  3. TREE
    TREE Heavy Load Member
    828
    367
    May 11, 2010
    OHIO
    I don't know the pro or cons but i glad i don't have the singles,at least till somebody prooves them better.
    Sorry if i wasn't any help.
  4. ACH1130
    2,695
    824
    Jan 23, 2011
    i agree with u too, i dont wanna use them till the prove them
  5. formertaxidriver
    formertaxidriver Heavy Load Member
    767
    375
    Jan 22, 2008
    Aiea, HI
    Get a blowout you're sitting. Oh yeah if you're heavy they may need to bring a rim too.
    ACH1130 Thanks this.
  6. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    They are profitable in certain applications, but I do believe the general consensus is no, you're not going to gain any in fuel mileage (mostly based on driving style) and no, saving weight is not worth the down time if you lose one.
    ACH1130 and ProPilot Thank this.
  7. Teaforone
    Teaforone Light Load Member
    200
    70
    Nov 16, 2008
    In the Sandhills, NC
    They have hardly any grip when its icy. They just can't dig into ice as well as dual tires.
    And as formertaxidriver said, they have the disadvantage that unlike duals where if you blow one you can possible limp to a safe spot to get it worked on, you must stop when you blow a single.
    On a similar post like this a few months ago I told the story of a driver on our account who when his super single blew it set his pull tarp on his double drop on fire. It also blew off the aluminum plating on the rear deck above the tire too.
    formertaxidriver and ACH1130 Thank this.
  8. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    When I drove for Central they were one of the first companies that was using them. When we got our truck I had them take them off and put regulars back on. Super single tires are economically good for large companies. They are lighter, won't rub together like two tires so they won't blow out from that. I however do not like them. I think they are bad in the rain! Hit a little water and they become a personal raft! They maybe a little better in the snow just because of more surface contact so better traction. Chaining would probably be about the same I would imagine. Downside if you are an O/O is they are very expensive, can't carry a spare, if you get a blow out you are stuck where you are at. They wear quicker due to more surface contact. (from what I have been told) Also get hotter due to more surface contact.
    Overall I would prefer regular tires. Even if someone else was paying for them.
  9. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    Back in '95 or so I had them on a trailer they sucked in rain or snow and as mentioned above when you have a blowout you sit....the rim drops to the ground or at least mine did..
  10. Rocky64
    Rocky64 Medium Load Member
    358
    137
    Oct 3, 2010
    Greater Chattanooga
    I am getting assigned my first ever truck with these supersingles, pulling tanker. I'm not looking forward to a blowout while loaded with 15-20# per gallon liquid. Wonder what the surge will be like.... Hmmm. Maybe end up wrong side up.
  11. Sequoia
    Sequoia Road Train Member
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    If you have super singles on your tractor and trailer, you're no longer an 18-wheeler. You're a 10-wheeler. :p
    Now supposedly you get better traction as there is more surface contact with the road. I didn't notice any difference. Supposedly they handle better. I didn't notice any difference.
    Only benefit I can actually say "hey, this is better than duals!"..you don't have as many valve stems to hit as you check your tire pressure.
    Tazz Thanks this.
