Supercharger vs turbocharger
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mizdageeragn, Mar 3, 2010.
  1. mizdageeragn
    mizdageeragn Medium Load Member
    358
    183
    Jan 22, 2009
    almost there
    Many years ago, actually about 40, I was a pretty serious gearhead running at US30 Dragstrip near Merriville,IN. It wqas a good place to run until the mayor moved into a house about a 1/2 mile from the track and his wife started moanin about the noise. Anyway the big thing back then to make a car go fast was to get a 671 blower from a semi on top of a high winding small block short stroked Chevy. We turned our 330 (327 punched 30 over but an ever shorter than stock stroke) over 10 grand every weekend. WE also had a big motor which was a 400cid small block punched 30 over with a 350 cid crankshaft and the special bearings to make the crank fit the block. We couldn't turn it over 9400 or it would blow the right rear side of the block off every time. Jensen used to run the same motors..Anyway long intro and now to the point. Back then the big truck motors made horsepower by using the superchargers(blowers) to force pressure into the intakes instead of waiting for atmosphere pressure. In today's world we use turbochargers to force air in and make horseys gidyup. When did the industry switch and was it a sudden change? Most importantly WHY did the trucking industry switch to turbo's..emissions??
    I've still got 2 complete, new 671's in the original boxes in the garage. Maybe it's time to find out if anyone needs one to restore a truck! Better yet I should restore an old cady,stuff a small block in it and lay the supercharger on top just to have some fun with it. Watcha think guys?
  3. fireman5606
    fireman5606 Bobtail Member
    36
    25
    Jan 24, 2010
    Shelby ,NC
    Correct me if I am wrong, but the only diesel truck engines that ran the superchargers were Detroit's, (and maybe a Mack or two?) and I am pretty sure some of them had a supercharger and turbo (8v92 or 318's maybe). Most of the other engine manufacturers used turbos. The 6-71 supercharger you refer too came from the 6-71 series detroit engines, they also had 2-71, 3-71, 4-71, and several others in the 92 series etc. The first number 2,3,4,6, was the number of cylinders and the last set of numbers was the series of engine(for example a 6-71 is a 6 cylinder 71 series engine). The 92 series engines 6v92,8v92 etc were v6, v8, v12 engines with the first number being the number of cylinders and the V for the shape of engine (V instead of in-line) and the last set being the series of engine as before. As I first said correct me if I am wrong as I very well could be.
    Also a turbo doesnt take power from the engine to add power it simply uses the exhaust to turn the turbine to force air in the intake. A supercharger requires a certain amount of HP from the engine to force the air. Generally speaking a turbo is more efficient. Again all of this is completely unofficial.
    mizdageeragn Thanks this.
  4. mizdageeragn
    358
    183
    Jan 22, 2009
    almost there
    So are you inferring the big truck diesels of 40-50 years ago basically all ran turbo's?
    Your post brought back a lot of info I'd completely forgotten about; Thanks.:biggrin_25514:
    My partner helped me put a 371 on top of the I?O boat I had at the time. Only lasted 2 seasons before it blew the bottom out of that old 231 v-6 but it sure made some great engine noises and was a tonoffun to ski behind!!That boat was up on a plane faster than a hydro!!
  5. fireman5606
    36
    25
    Jan 24, 2010
    Shelby ,NC
    Well I wasn't around 40 yrs ago so I am not sure exactly when they started using turbo's on most of the engines, but to the best of my knowledge Detroit is the only one that used the superchargers atleast in trucks. I can't say exactly when diesel engines started using turbos in trucks, but I am sure some others on here will know. I know Cummins had turbos and superchargers on their racing engines all the way back to the 1930's.
  6. phroziac
    phroziac Road Train Member
    3,138
    502
    Jun 16, 2009
    Gary, IN
    I wonder what would happen if i put a turbo from a truck in my car.....maybe a cat twin turbo setup...
    and Im laughing at the "turbo doesnt take power from the engine to run it" comment. Bull. It adds exhaust backpressure, takes the power right off at the pistons.
    Both of them add way more than enough power to make up for it....
  7. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    I think the 71, 92 is the cubic inches per cylinder
  8. ironeagle2006
    ironeagle2006 Road Train Member
    The reason Detroit ran a Supercharger was very Simple. The OLD Detroits were a 2 Stroke Design and needed a Postive Pressure for Scavenging of Exhaust at ALL TIMES. Think of an Old 6-71 as say an EMD GP-38 expand the motor to 16 clyinders and you have the same design. EMD General Motors Locomotive builder still to today builds a 2 stroke engine with a Supercharger on it however they came up with an overrunning clutch were at 75% power or more it overrunns and becomes a Turbo. They get up to 5000HP out of a 20 Cylinder motor that has 710 Cubic INCHES PER CYLINDER.
  9. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Turbos produce "free" scavended energy while the supercharger requires power from the crank. That would be my guess as the biggest reason why turbos are main stream in the trucking industry.
    Dont get me wrong, superchargers are awesome, and offer some tremendous advantage over turbos. I freaking love hearing an old supercharged 671 or 871 Detroit on an excavator. They sound like their gonna go grenade at any second lol. Just hang her out wide open, and go to work!!!
    7mouths2feed Thanks this.
  10. BrainHurtz
    BrainHurtz Light Load Member
    245
    57
    Jun 24, 2008
    Terre Haute, In
    Superchargers by definition use power to make power, turbos are virtually free, extracting waste energy in the exhaust stream and converting it to useful work. Detroit has taken this one step further in the new DD15 adding a turbo that directly uses the expansion of the exhaust to add power right back to the drivetrain, with real noticeable gains to fuel economy.
  11. Commisoner Gordon
    Commisoner Gordon Bobtail Member
    7
    Fairport NY
    Man o man Sundays at US 30 Dragstrip...Those were the days... Art Arfons Green Monster, Arnie The Farmer Beswick, Chris Karmazines..
