Suppport Thread for the TND 500, TND 700 or future Rand McNally products.
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Mark Kling, Apr 16, 2010.
Thread Status:
Not open for further replies.
  1. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    This thread is being started as a support thread only. No comparisons or discussions about other NON-Rand McNally navigation devices or software.
    I am Mark the Lead Beta Tester for Rand McNally for their line of navigation devices such as the TND 500 and the TND 700. If you have concerns, questions or your TND is just not performing correctly please let me know the details of your issue.
    I monitor this thread daily to include weekends. My E-Mail is shown at the bottom and even if I am on a "road trip" I will receive your E-Mail.
    I am bringing this over from another thread that is more of a general discussion type of thread. I will monitor that thread, but support questions should be addressed in this thread.
    Thanks and bring it on...
    Mark
    :biggrin_25519:
    MoneyCat, sinker, Balakov100 and 17 others Thank this.
  3. TruckerDude53
    TruckerDude53 Light Load Member
    57
    9
    Nov 26, 2009
    Buckeye, AZ
    Hey Mark, now I'm not sure whether to ask here or the other thread.. but here goes. Twice now, I've driven from Inianapolis to Denver... what should be a simple route straight west on I 70. The TND insists on trying to get me to go north and take smaller roads to go west. Shortest or Fastest setting doesn't seem to make any difference. Am I missing something here?
  4. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Rand sees the issue... they are looking at it now..... the route is correct from B to A but not A to B...
    Thanks for this,
    Mark
    Skydivedavec Thanks this.
  5. Dieselboss
    Dieselboss Technology Contributor
    1,648
    1,365
    Feb 19, 2009
    DieselBoss.com
    Yup. That would be a question for THIS thread. :biggrin_255:
    Also, I just played with your scenario using standard 53' truck/trailer settings.
    Indy to Denver (shortest) 1064 miles (goes west on I74 to I72 to US-36)
    Indy to Denver (fastest) 1070 miles (goes west on I74 to I72 to US-36)
    Both are straight forward routes but they do NOT use I-70.
    Then: (using I-70 by touching a spot on that road and adding it as a waypoint.)
    Indy to Denver (fastest) 885 miles using I-70.
    Indy to Denver (shortest) 887 miles using I-70.
    Yup - you have a legitimate question my friend. :yes2557:
    Skydivedavec and Mark Kling Thank this.
  6. pete159
    pete159 Light Load Member
    106
    68
    Dec 6, 2008
    mississauga
    i was out driving around with the tnd in my car to test it out. The battery ran out. I went home and charged it, it was in standby mode when i started charging it but i did not know that at the time. After it was charged i turned it off and back on, and the map is showing me at the location the battery ran out instead of being at home.
    Will that change once i start driving again or is there a problem.
    ok after many hours of being home the map now shows me at home.
  7. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    It is a GPS device, to show your physical location it has to be able to receive satellite signals. Sometimes in a house will block the signals to a point it may take awhile to receive a good signal. Going outside for about 5 minutes will put your GPS back on your physical location.
    Thanks,
    Makr
  8. ChromeDome
    ChromeDome Road Train Member
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    So when will I be able to add that spot as a waypoint on my 500? Or was that in the update my computer just downloaded?
  9. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    That was POI and construction updates... The next Version has not cleared QA yet.... and yes waypoints are in it..
    Thanks,
    Mark
  10. TruckerDude53
    57
    9
    Nov 26, 2009
    Buckeye, AZ
    I thought there was a way to route a trip from point A to point B while you are sitting at point C. Something to do with "set as origin"? I can't seem to make it happen now. Can you point me in the right direction? (fitting pun)
  11. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    find your first location, instead of hitting begin route, at the bottom is a 'set Origin" button... click on that... it will take you to the map screen.. then go to the main menu again and find your second loction and now begin route....
    It should now show you from point A to B while sitting at C.
    Thanks,
    Mark
    snowman01, TruckerDude53 and jimo Thank this.
  • Thread Status:
