Suspension weight ratings
Discussion in 'Peterbilt Forum' started by Sandsailor, Mar 25, 2023.
  1. Sandsailor
    Sandsailor Bobtail Member
    21
    9
    Feb 26, 2023
    I don’t know if this is the correct place to ask this question, but I been searching online for the Peterbilt Flex Air weight rating.
    as far as I found somewhere it said that it came for 38k on the suspension(flex air) and the differential are Eaton 40k
    my truck has Flex Air, so I’m guessing my tandem weight limit is 38k?
    Or is there different ratings for Flex Air? I know someone who has grossed 105k, which would put his trailer and tractor tandem at ~46k.
  3. Animosus
    Animosus Heavy Load Member
    730
    2,892
    Dec 7, 2015
    SE Wyoming
    AG-380 / Flex Air is a 38k suspension.
    Rideandrepair, Sandsailor and Oxbow Thank this.
  4. Cat sdp
    Cat sdp . .
    21,196
    75,208
    Apr 8, 2012
    Orion's Belt
    Isn’t the rears stamped inside the door jam ?
    Rideandrepair, Magoo1968 and Oxbow Thank this.
  5. Sandsailor
    21
    9
    Feb 26, 2023
    the rears are rated for 40k, but the Flex Air suspension is supposed to be rated for 38k hence my question.
    https://www.pbtruck.com/Parts/Catalogs/Peterbilt-Suspensions.pdf
    if you look at this chart it shows Flex Air as 38k. Just wondering if there’s other ratings
    Cat sdp and Rideandrepair Thank this.
  6. Sandsailor
    21
    9
    Feb 26, 2023
    I suck at seeing replies here. That’s what I was thinking but almost always there’s information I don’t know about and like to double check.
    Rideandrepair Thanks this.
  7. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Just go off the door sticker.
  8. Sandsailor
    21
    9
    Feb 26, 2023
    So I finally got around to checking my door sticker(I was in another).
    my door sticker says:
    gvmr: 50,000lbs
    Front axle: 12,000
    2nd axle: 19,000
    3rd axle: 19,000
    which would total at 38k for the Flex Air.
    but this confused me. My brother has the same truck but a 1999.
    This are his specs with a Low Air Leaf
    Gvmr: 48,000
    Front axle: 12,000
    2nd axle: 18,000
    3rd axle: 18,000
    And we always assumed his was a regular 40k tandem and he has permitted up to 46k on those and driven many miles, I asked him if the DOT had checked that before, he said, they just look at the permits and send me on my way.
    Another friend with a 90s 379 as well, showed me a Class 1 inspection he had today and he also had a GVWR of 48,000 with low air leaf. As far as I know, Low Air Leaf was 40k yet they have lower GVWR than my Flex Air.
  9. Last Call
    Last Call Road Train Member
    7,568
    45,910
    Mar 15, 2021
    Low leaf has a higher rating than Flex Air
    Pernsonaly I don't care for flex air more wear points I think they ride worse and it weighs more than a low leaf
    I have yet to see any sort of advantage to flex air
    NightWind Thanks this.
  10. Sandsailor
    21
    9
    Feb 26, 2023
    I agree about the wear points, I haven’t driven a low air leaf in 8 years so I can’t really compare the ride. Only thing I have against flex air is they lean a lot on curves.
    but my truck is lighter, with a heavier engine, I think the Flex Air is supposed to be 400 pounds lighter.
    my big question was on weight ratings, but according to Peterbilt they gave Flex Air a higher axle rating than both of the low air leaf that I looked at. So I keep scratching my head about the tandem weight limit.
  11. AModelCat
    161,606
    They probably make the suspensions in different weight ratings.
