Swapping a 13 speed manual to a X-Y shifted 13 speed?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 6cuda6, Jun 19, 2021.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Ok, i know its been done auto to manual but has anyone ever done it the other way around? I'm just asking incase "the one who must be obeyed" decides their is no way in h*ll she is gonna shift this manual. And no it's not cheaper to change trucks for an auto [not by a long shot for what i have in this one]
  3. Goodysnap
    Goodysnap Road Train Member
    3,734
    9,083
    Jul 12, 2017
    The auto shifters are so tied into the truck you would be far better off to trade up. The market is literally flooded with them. Over 3/4 of new trucks sold are auto.
    I would not wish to buy your maunual truck hacked up to auto.
  4. 6cuda6
    259
    176
    Oct 9, 2020
    I hear you and agree but this truck has been swapped to "none commercial" registration so its fair to say its "game on".
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Easiest thing to do is find the same make and year of truck you currently have but with a first or second gen auto shift in it. That way you can swap out the transmission, its wiring harness, tcm and hopefully it has the same engine so you can swap the ECM as well. Its gonna be a big project and lots of $$’s. If the truck is new enough or you wanna ditch the clutch pedal you’ll need to swap out all the air operated clutch components as well.
    6cuda6 and Flat Earth Trucker Thank this.
  6. 6cuda6
    259
    176
    Oct 9, 2020
    Yah i was thinking a salvage setup might be the best avenue but was hoping it might be simpler like a top plate, X/Y shifter, controller and harnessing....sounds like i'd be digging a hole for myself....simpler to get a comllete swap or pay someone to teach the wife how to shift this truck.
  7. Big Road Skateboard
    6,507
    36,500
    May 2, 2021
    The autos wiring is integrated into not just the engine ECM, but also ABS, and other truck ECU's.
    Installation will be easy. Making it operational not so much.
  8. Goodysnap
    3,734
    9,083
    Jul 12, 2017
    Have you started with something simpler. Buy an old beater car or pickup with a manual and get her use to that first.
    Jumping into a big truck like that to learn to drive a manual can be very intimidating. If I were you I would keep working with the wife, save yourself alot of money, time and headache.
    In the end, like most real truckers, she will have a skill that cannot be forgotten.
    spsauerland and 6cuda6 Thank this.
  9. Roberts450
    2,237
    3,638
    Feb 6, 2016
    One of the other main differences in the transmissions, least back when I was in school learning about them in the early 2000’s, is the sliding collar has narrower teeth so the x/y shifter had a better chance on getting the collar fully engaged in the gear during the shifts.
    6cuda6 Thanks this.
  10. 6cuda6
    259
    176
    Oct 9, 2020
    She can drive standard ( hasnt for many years) but i think the number of gears is intimidating her verses the possible traffic. I keep telling her the truck has lots of power so she can pretty much pick any gear and it will move.
    Quess i just have to get her to practice.
    Roberts450 and Goodysnap Thank this.
  11. AModelCat
    161,206
    In the long run, even if she DESTROYS the manual transmission while learning you'll still be time and money ahead vs converting to an autoshift.
