Swapping a 13 speed manual to a X-Y shifted 13 speed?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 6cuda6, Jun 19, 2021.
  1. DUNE-T
    DUNE-T Road Train Member
    6,978
    16,934
    May 10, 2015
    Detroit, MI
    Just teach her to drive it like a 9 speed.
    I swapped 3 10 speed auto shifts to manual and it's fairly easy. Like you said, top plate, harness, shifter and ECU reprogramming. However going backwards I think will be a huge and expensive pain in the rear. You will have to find a vin number of a truck similar to yours, get all the parts based on that Vin, install everything and program. It's gonna take a lot of time and money
    baha and 6cuda6 Thank this.
  3. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Yah im hearing you guys load and clear....im just going to let her figure it out....worse case, as someone said, she kills the tranny and if so ill swap in another... im seeing the light....lol.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    1st buy a older rear wheel drive car with a clutch and teach her how to drive it with/out using the clutch (speed shifting) till she stops and she will be ahead of the game and not grind the truck gears as many times as she learns to double clutch the truck and will be only using it only when she stops the truck, after she learns and you can sell the car after she gets shifting it with out touching the clutch pedal down to a art??
