Swapping Cummins ISX for a 60 Series
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Harleybilt379, Aug 28, 2019.
  1. Harleybilt379
    Harleybilt379 Bobtail Member
    9
    Jul 16, 2019
    So, We got a blown ISX in a 05' Peterbilt 379. The boss wants me to take a 60 Series Detroit out of a 04' Freightliner Classic and put in the Pete. Now, I've already made my mind up that this decision is going to turn into way more time and money then it's worth. I have reasons why, but would like to hear your reasons why this can or can't be done...all comments on this subject are welcome and the more the marrier!
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Run the classics save the headache. Heck does your boss need a driver for the classic?
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    That 379 was not designed to have a Detroit engine. And even if you could get it mounted in how would you get all the wiring to work together on it. And all the other components around the engine.
  5. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Legal reason.
    You cannot go backwards in engine build year.
  6. CountryBumkin
    CountryBumkin Bobtail Member
    43
    39
    Jun 4, 2018
    Is it engine build year - or the year the engine emissions is built/certified for, that matters?
    In the motor coach world, many coaches are built with engines that are older than the coach's build year.
    For example my 2005 Monaco (Beaver) motor coach has a CAT C13 (525 HP) with a build date of 2004.
    Supposedly the coach manufactures bought a bunch of chassis and engines, and then used them as orders came in, so older engines in newer models was common.
  7. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    You would need to take the engine to firewall harness off and send it to malk industries. They will rewire it all to work with that Detroit.
    The rest is just nuts and bolts. Probably have to rob the engine mounts out of the classic also.
    Intothesunset Thanks this.
  8. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    It can be done, it just takes time and money, but every part needed is available.
    How many new pete gliders are built with detroits?
  9. Harleybilt379
    9
    Jul 16, 2019
    I agree with running the classic, and yes we could use a driver for it!
  10. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    I think in this instance you have it wrong. If for instance both are EPA2004 emissions standards then going backwards wouldnt be illegal since both are using EPA2004 standards. While year build is important the EPA standard would take precedents over the legality of the swap.
    daf105paccar Thanks this.
  11. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    In those years a lot off engines were build under the credits system,if you remember.
    A grey area at best.
    Socal Xpress Thanks this.
