swift elogs question
Discussion in 'Swift' started by southernride, Jan 20, 2012.
  1. southernride
    southernride Bobtail Member
    14
    10
    Jan 13, 2012
    muskogee oklahoma
    I have drove be for but have not for little over a year.Im looking forword to coming back to it.I am going to oreintation end of the month.I havent drove for over year so I have to go with mentor for a bit.My question is on the elogs maybe a dumb question but have to ask.how does it work if you have to have your last seven days of logs with you at all time.does the student run paper while on truck.just dont understand how this works.
  3. blsqueak
    blsqueak Road Train Member
    3,988
    3,284
    Dec 27, 2009
    buckeye lake, oh
    You will not run paper. the e-logs stores the last 7 days.
  4. driver7702003
    driver7702003 Medium Load Member
    300
    51
    Nov 12, 2011
    FLORIDA
    You will run paper until you are in youre own truck unless that has changed in the last month or so that is what a swift mentor told me
  5. inkeper
    inkeper Road Train Member
    1,440
    1,059
    Jan 30, 2011
    Texas
    If you get stopped and are asked for your last 7 days there is a fax function to send the logs to the DOT officer. Or he can get up in your truck and look at the Q/C himself.
  6. Switches
    Switches Light Load Member
    219
    90
    Dec 15, 2011
    PHX,AZ
    On your mentor truck you "Will" Be required to run both paper logs and E-logs. Do Not sign your Paper logs or you will be in Violation and running multiple sets of logs. You need to know how to do both so you will be doing both on the mentor truck. They will most likely not match up at the end of the day but don't worry about it. On paper we round to the nearest 15 E logs are by the minute so they wont match. Roll on what ever the E log says you have at the end of the day that is the one that matters right now.
  7. Trunch
    Trunch Bobtail Member
    23
    5
    Jan 16, 2012
    so cal
    Got a ?What happens when u go over the 11 or 14,how long canu drive for and what should u tell safety about it?Also how many times can u do this before u get into trouble?
