Swift in Canada??
Discussion in 'Swift' started by cannuck, Jul 28, 2009.
  1. cannuck
    cannuck Light Load Member
    73
    24
    May 22, 2009
    Grandview, MO
    Does Swift goes to Canada? if it's the case does it depends on the home terminals to get the runs to there or i can request it?
  3. tinytim
    tinytim Road Train Member
    5,143
    18,113
    Oct 29, 2007
    Northern Ontario
    I see them up here now and then. Can't help with the rest though.
  4. luvtheroad
    luvtheroad Road Train Member
    1,734
    488
    Jan 1, 2009
    Central Ohio
    dont know about them but I know Werner does. they have a terminal in the toronto area
  5. Darkschneidr
    Darkschneidr Light Load Member
    296
    77
    Jan 31, 2009
    Phoenix, AZ
    Yes, Swift does run into Canada. You will likely need to be based from one of the northern state's terminals, as the hours of service are different there. Sumner is one terminal where many Canadian loads get T-called.
    cannuck Thanks this.
  6. cannuck
    73
    24
    May 22, 2009
    Grandview, MO
    so basically i'll need to relocate?
    i tought i could request to get a run to there if there's some available.
  7. starcommander
    starcommander Light Load Member
    Check with your DM or find who to talk to within your company and ask how you can go about arranging this if at all possible and the paperwork that is involved.
    P.S. Make sure that you have your passport.
  8. starcommander
    Yes our hours of service are a little bit different up here but if you run here using your HOS rules that you run under everyday then you will be fine over here as well as being compliant on you side of the border when you go back over. Keep in mind that you will need at least 60 dollars US for tolls on the bridge at Detroit/Windsor. $22.50 max gross weight coming into Canada or going back into US plus $10.75 US for US Customs Fee.
  9. cannuck
    73
    24
    May 22, 2009
    Grandview, MO
    i have my canadian passport since i'm a CDN citizen plus i have a US permanent resident card so that won't be a problem... i'm eligible for US citizenship in 2011, after that it will be easier to cross the border
    i hope to get runs in Quebec lol
  10. starcommander
    Cool. Sounds like you have those bases covered. Now see about finding the right person to talk to about putting your plan in motion. Good Luck. FYI: :biggrin_25525: Stay away- I repeat stay away from those little French Girls. It has been rumored for years that they can and will `HURT` you! :biggrin_255::biggrin_25526::biggrin_25523:
  11. cannuck
    73
    24
    May 22, 2009
    Grandview, MO
    i can tell by experience lol i used to date them back in the days
