When I upgraded I had to do 2 blindsides, 2 sightsides , a parallel park and straight line back. The spot was almost 2 trailers wide, unlimited pullups and goal all you want, so easy as can be. As for the road test It was pull out of terminal, drive a few miles then back, again very easy. This was at Lancaster,TX probably varies depending on where you are.
If you are fresh out of school you will go out with your mentor before a road test so you will have 240 more hours btw the practice.
