Just got this truck today. No idea what these switches are for(rear/front) anyone know?![]()
Switch icon identify
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ryan87, Aug 11, 2015.
Ummm....
Air bag dump? No that makes no sense. Did you try them? Operators manual?
looks like a dump valve for each of the rear axels and a dump valve for the tractor...
are you running tag axels ?? -
Did it used to be hooked to belly dump trailers?
The truck was a custom order. It has pulled a salt water transport from day one and the trailer has leaf springs. I did try them. Didn't seem to do anything.
thanks for all the input. I just got the truck a few days ago and it there are some things about it that are a little confusing. There are wires with plugs that run to the front of the truck where you would normally have that extra plug for additional running light that says fog lights and the truck doesn't have a fog light switch.
Check for a 4 or 6 prong plug behind the cab. Those switches should provide power to different pins. I believe that Cetane+ is correct that they are belly dump controls. Even though it only hauled salt water they may have specified this configuration to have another option incase the water died off.
I've seen them on a lot of Petes, I was told that they are for belly dump trailers, but I have not seen anything official on that, nothing in any manual I've found. Everyone I've seen did nothing, they were plumbed to 2 ports on the firewall by the steering shaft, but capped off.
Ours are car haulers that have suspension over lifts. We used one of them for that because it was a preplumbed air switch and all we needed to do was run an air line for the plugged port to the over lift pilot valve. We just used a label maker to put "Over Lift" over the icon on the switch.Cetane+ Thanks this.
