Switching 22.5's to 24.5's
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big John, Mar 12, 2011.
  1. Big John
    Big John Road Train Member
    2,022
    1,521
    Oct 7, 2006
    Oklahoma
    I am thinking about switching my wheels and tires from 22.5's that I have know and putting on tall rubber 24.5's. I don't care about the fuel mileage because I just pretty much run local and loaded heavy. I need it for the ground clearance and want to be able to finish running out my steer tires on my trailer which already has 24.5's. What I need to know is what will it do to my drive train, will it do anything to my speed and shifting?
    I have '01 KW T800 with a ISX 475, 10 speed and 3:70's running 22.5's tall rubber.
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    SoDel and Big John Thank this.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    anyway after you change tires do EM reprogramming to get correct speedo reading
  5. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    It will only change your MPH a little. We have 2 trucks on 24.5's with 3:70's and all do great. I have the instructions and chart to change your KW speedo if you want it. You just need to flip the switches on the back of the gauge.
  6. Big John
    2,022
    1,521
    Oct 7, 2006
    Oklahoma
    Thanks for the info, I just didn't know if it was going to change they way it ran like lugging the engine more or it would take longer to get up to speed. I have never switched tire and wheel size on a truck before and didn't know what to expect.
  7. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    I've never went larger, always smaller. Took one from 24.5's to LP22.5 Super Singles, really no issue there since it runs local pulling a hopper so speed wasn't an issue. And just took another from 24.5's to LP24.5, this one was the biggest change. It was geared perfectly 24.5's 3:36's and a 13spd, any speed below 65 you just ran 12th gear and 65+ you used 13th. But after the tire change 12th kept the RPM too high and the truck didn't have enough power to run 13th (always hauls permit loads up to 120k). It was right on the line and extremely annoying, in 12th at say 60mph it ran 1500rpm and 13th it was down to like 1250-1300. The truck is a C15 Acert so 1350 is the sweet spot. Ended up going with a stage 1 PDI tune and now power isn't an issue and it can just stay in high gear.:biggrin_25525:
  8. Don2WS
    Don2WS Medium Load Member
    306
    26
    Feb 26, 2010
    Sturtevant WI
    do you happen to have the instructions still i have an 03 t800 with c15 13 speed and 3.70s truck came out the factory with 11r22.5 but dealership switched out to 295/75/22.5 so speed is off by a couple i have to use the gps to make sure of my speed
  9. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    I have the formula and chart in a file at work. I'll get it tomorrow and send it to you.
    Don2WS Thanks this.
  10. sgosine577
    sgosine577 Bobtail Member
    4
    miami lakes
    I changed my rear end from a ratio from 3.58 to 4.56 when converting a tractor to a rolloff truck. I am using regular 22.5 tires and i noticed that my speedometer is reading 60 mph when it should be reading 48mph per my gps. Would changing to 24.5 decrease my RPM and increase my speed reading ton the speedo.
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    low pro 24.5 is the same height as 11r 22.5 I took off my l.p. 22.5 & put on 11 r 22.5 which gave me a lil more top end speed. so m.p.g is better, but less pulling power on the hills. I cannot say which is better over all on m.p.g. cause I changed over 1 month after I bought my truck. some say less r.r. with low pro.. but they will also have a higher r.p.m. too. good luck.
