Switching from 11R 22.5 to 295/75R 22.5 Volvo VNL 670
Discussion in 'Ask An Owner Operator' started by gekko1323, Apr 2, 2025.
  1. gekko1323
    gekko1323 Road Train Member
    1,586
    2,650
    Jul 14, 2018
    Henderson, NV
    Good afternoon, folks. I hope everyone is doing well out there.
    So, I bought my 2nd truck. It's a 2012 Volvo VNL 670. The truck is a 10-speed, 475 hp, 3.55 rear ratio on 11R 22.5 tires. It runs like kitten, with a rebuilt engine and tranny. I'm trying to get used to the gear box because you can't feel or even hear the stick as you shift. I'm really happy with it and might even sell my Columbia. I don't know, we'll see. The drive tires are the only thing bugging me because there are like 3 different brands with different wear levels. That's not how I roll (pun intended). So, I'm thinking of getting a whole new set. The rims are steel, so I might switch to aluminum.
    I might be able to save 3 grand in the short term by switching the rims and tires with my Columbia. The drives on my Columbia have less than 90,000 miles on them and look brand new practically. And the rims are aluminum. So, I'm wondering how this will affect the performance of the truck. How will the torque, rear ratio, fuel efficiency, tachometer, etc. all be affected? Will I need to do any software reprogramming since the Volvo's specs/parameters were based on the 11R tires? How about pulling power? I run a lot in the mountains, so this is also a concern.
    Thank you all in advance for your advice.
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    148,594
    Id say you wouldnt notice a difference at all. Truck will sit maybe an inch lower to the ground, if that.
    low pros are alot easier to find out on the road if u have a blowout or need a new one. If just doing highway work , low pros are the way to go
  4. Siinman
    Siinman Road Train Member
    5,286
    13,377
    Mar 5, 2017
    Kansas City, MO.
    Here's a breakdown:
    • 11R22.5:
    • 295/75R22.5:
    • Rolling Circumference: While both tires use a 22.5-inch rim, the 295/75R22.5 has a slightly smaller overall diameter due to its lower profile, resulting in a marginally smaller rolling circumference.
    • Practical Implications: The difference in rolling circumference is small and likely won't be noticeable in everyday driving. However, it could affect speedometer accuracy and slightly alter the gear ratio, which could affect acceleration and top speed.
    OldeSkool and gekko1323 Thank this.
  5. abyliks
    abyliks Road Train Member
    3,888
    9,091
    May 2, 2010
    ludlow MA
    Speedo will have to be recalibrated, will basically drive like you have 3.70s on current rubber so probably gain ~100 rpm
    Rideandrepair, Bean Jr., Oxbow and 3 others Thank this.
  6. 062
    062 Road Train Member
    6,216
    33,464
    Oct 20, 2013
    You may have to change the studs,aluminum wheels are thicker.
  7. gekko1323
    1,586
    2,650
    Jul 14, 2018
    Henderson, NV
    I thought that the gear ratio would go down to like 3.32 because it would take less turn of the shaft to complete one turn of the wheel?
    Rideandrepair Thanks this.
  8. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    Other way around.
    Think of it this way….longer legs take fewer steps.
  9. gekko1323
    1,586
    2,650
    Jul 14, 2018
    Henderson, NV
    I just can't wrap my head around it. If it takes 3.55 turns of the shaft to turn the 11R once, wouldn't it take less turns to turn the 295 since it has a smaller diameter?
  10. 062
    6,216
    33,464
    Oct 20, 2013
    Look at revolutions per mile. 11R turns less revolutions than a lo-pro.
  11. plant
    plant Heavy Load Member
    813
    707
    Sep 21, 2012
    Los Angeles, CA
    It will take 3.55 turns of the shaft to spin a tire of any size one time, that never changes.
    The difference is how much distance you will travel during that one rotation of the tire. A lowpro will travel a shorter distance, so you will need to run a higher RPM to go the same speed you did running 11Rs, effectively giving you a lower (numerically higher) gear ratio like 3.70 as another user said.
