Switching from 9 speed to 10 speed.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Drew2012, Apr 29, 2012.
  1. Drew2012
    Drew2012 Bobtail Member
    5
    Oregon
    Hi everyone, this may be a stupid question and may not be in the right section, sorry I'm new here. I have been driving for about a year now and have only used 9 speed transmissions, well except for training which was in a 13 speed. I'm switching to a new company soon and they use Eaton Fuller 10 speeds in their trucks. I get the basic idea, 1/6 is where Low would be on a 9 speed. But is there anything special I should know when transitioning? Do I shift at a lower/higher RPM? Any advice would be appreciated. I didn't think I'd encounter a 10 speed in a newer truck because my old company said they where being phased out of new trucks. Apparently they were lying or were misinformed.
  3. highside
    highside Medium Load Member
    441
    510
    Feb 6, 2010
    Kansas
    Shift at the same RPM as a 9 speed...*maybe* 50 RPM less, but the steps are so similar between the two transmissions that it's barely noticeable. You'll do just fine.
  4. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    Drive it just like your 9 speed and use 6th when you need to. It's common to skip 6th in a 10 speed because of where it is, but it's there if you need it.
  5. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    The only thing you have to remember is to hit 6th gear instead of jumping from 5th to 7th or from 7th to 5th. Other than that, drive it the same way.
    CondoCruiser Thanks this.
  6. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Let me explain the 10 speed in a nut shell: It shifts much faster and smoother than a 9 speed. You can shift at higher RPM's and float with the 10 speed, where as the 9 speed if you shift at a higher RPM and try to pull out you usually have to use the clutch. It is a delight to drive, I can go from 1-6 in 5 seconds, try that with a 9 speed. There is a video posted showing me shifting a 9 speed, if you don't wait for the RPM's to drop when shifting, it grinds.
