Switching from a 48 to 53'
Discussion in 'Flatbed Trucking Forum' started by playamwj12, May 26, 2016.
  1. playamwj12
    playamwj12 Heavy Load Member
    810
    930
    Aug 22, 2012
    I am switching from a 48' spread axle flatbed to a 53' all aluminum great dane.
    Looking for advice on keeping my weights legal. What to look for? I haul a lot of coils so im guessing it changes where. i would sit one big coil now. Mainly lumber, crane mats, pipe, flat steel and coils.
    Ive heard that in CA TN CT and FL the back axle must be pushed forward. Can anyone explain this? Do i still get 40,000 or less with it forward?
    I know yall have an immense amount of knowledge hopefully you can.help. thank you,
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,500
    9,782
    Mar 30, 2014
    No, you only get 34,00 when the tandems are together.
  4. Ruthless
    Ruthless Road Train Member
    8,931
    87,838
    Aug 28, 2010
    The City.
    Sounds like all if what you do fits on a 48...... Why upgrade?
    playamwj12 and TripleSix Thank this.
  5. TripleSix
    129,340
    Bridge law.
    There are 2 types of 53 ft trailers used. One type has the spread moved forward so that theres a 10 ft tailswing (Swift and Hunt uses these). These types are under the bridgelaw in CT, CA and FL. Florida BTW gives you 44000 on the tandem, regardless of what kind of trailer.
    The 2nd type is the more popular for owner ops and specialized carriers. It has the slideable rear axle. While some places will give you theblues because of the bridge law, this trailer, because of the wheel positioning makes loading longer heavier loads easier to get the axle weights right because the load center is farther back.
    And the sliding axle gives you an extra adjustment. Closing the spread will move 2500 lbs from the drive axles to the trailer.
    SoDel Thanks this.
  6. TripleSix
    129,340
    I agree. If i was pulling a flat, id much prefer the 48 ft. The only way i would think about going to a 53 would be for a stepdeck.
    A 48 spread is easier to maneuver than even a 53 tandem.
  7. nikmirbre
    nikmirbre Road Train Member
    5,407
    9,729
    Jul 27, 2011
    High Point NC
    I upgraded to a brand new 53fl last year…..you gotta be careful. Ive found that some states you either have to be open 10ft to be considered a spread or anything closer than that and your considered a tandem….. I run with mine closed all the time due to better tire wear. But, I understand you can't do that all the time if you pull heavy loads…..
    whoopNride Thanks this.
  8. playamwj12
    810
    930
    Aug 22, 2012
    Repowering a load for my company. They want me to take that trailer and just work my qay back to it and swqp back. I own everything on my trailer and dont want it stolen so thats out of the question.
    I really appreciate it. I read a lot of what you post trying to feed off the knowledge youve gained over the years.
    Thank you i will keep that in mind!!
  9. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    8 foot spreads or less aren't even worth having as a spread. You're limited to 34.
    I pulled a 53 step and found that extra 5 feet wasn't worth the hassle. Never got used. And shippers HATE loading trailers with closed axles. Most of my loads on the east coast went through tennessee. Most of my loads on the west went to california. East coast shippers didn't complain much as none of the loads came close to 40k. But california HATED me. Even pissed off a broker in new york. She had 4 wide crates. One was 14 wide and the other 3 were 11 wide. The trailer weighed 37k so one box had to go on another truck. She knew i could haul 40 on the trailer but couldn't understand why i couldn't in california.
  10. MidWest_MacDaddy
    11,151
    18,751
    Feb 21, 2015
    South Carolina
    Wow... Sounds a bit complicated to this Dry Van company guy.... Maybe there is a Cliff Notes version or a FB for Dummies book??? ;-)
    whoopNride and G13Tomcat Thank this.
  11. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,142
    Jun 7, 2011
    ^^^ Confusing to us tank yanks, too! That's why I dread winter when I've gotta haul precast, out of asphalt season. : (
