SWR...Am I safe with this?
Discussion in 'CB Radio Forum' started by John_DeereGreen, Feb 17, 2008.
  1. John_DeereGreen
    John_DeereGreen Bobtail Member
    Athens, Ohio
    First off, this is my first post in any of the forums. Thanks for letting me join in on your community. I've got a 1997 Ford F250 that is my daily driver and cattle hauler.
    Here's the setup I put on the truck yesterday:
    Antenna: Radio Shack number 21-988
    Spring: Radio Shack number 21-1118
    Coax: 20 feet of "CB, scanner and HAM Grade 50 ohm" Radio Shack coax.
    Mount: Custom fabbed 1/4 inch steel bolted to side of the toolbox
    I've got a ground running from the mount to my bed to ground the mount; after hooking up a friend's SWR meter, I'm right at 2:1, with 40 ohms of impedance. I think this is a little bit high from what I've heard and read, but I'm no expert at this stuff. Also, I know that Radio Shack isn't the best place to buy stuff for this, but I got everything I needed to do what I did for $24.00. I really don't want to have to redo anything, but if it's what it takes to get it right now, I am willing to do it.
    Thanks for any input on this!!
    Matt
  3. C_Knight
    C_Knight Bobtail Member
    22
    Feb 16, 2008
    Lake Charles, LA
    Your safe with it. SWR is, in laymens terms, your signal strength.
    Not a real accurate definition of SWR.
    The lower your SWR the better. If it was up around 4 or higher you would risk burning out your CB.
    What you can do if you want to bring your SWR down is you need to trim your Antenna. If you have a metal whip just clip the top of the antenna. Don't take too much or you will end up buying a new one. It'll take about an hour of clipping and getting a reading to get your SWR down to about 1.5.
    Your not bad where you are now. If the current set up does the job you need it to do. Then I would leave it alone.
  4. thetez
    thetez Medium Load Member
    380
    24
    Jul 10, 2006
    its not great, but im gonna have to say your safe with it, radio shack coax and such is pretty good stuff actually, i know a few hams that swear by the stuff, your setup sounds pretty functional, only thing i would change is the antenna for something name brand. and 102" i dont know how far you wanna talk, or loud or any of that, but a new antenna would be the first thing i would upgrade. ....
    blah!!! thinking about it, the place probably isnt a very good one. you probably need to either dual it up or try and center the antenna somewhere. maybe on the back of the tool box.. instead of the side (if thats where it is) its not an ideal place but its better there then on 1 side. The only thing youll need to worry about there is your antenna below the cab back of the cab, it could mess up your signal, you may only talk infront of you or in back of you or something... trial and error my friend....
    a longer antenna will pobably make the swr a little lower anyway, and a lot easier to tune
  5. John_DeereGreen
    Athens, Ohio
    Thanks a bunch guys. I'm getting my friend's meter again tomorrow and going to an open field here on the farm and doing some more tuning. The plan down the road sometime is to dual the antennas up, but I don't want to do it right now. I just wanted to to make sure I wasn't going to burn my radio up...thanks again!!
  6. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,164
    Jan 17, 2008
    Wherever and Whenever...
  7. wc5b
    wc5b Medium Load Member
    322
    52
    Nov 5, 2007
    Flint, MI
    Anything under 3:1 is fine. Anything 2:1 and under is good. Anything under that is excellent. Don't worry unless you start going 3:1 or more.
    And, no offense, but to the other replier, SWR is not even close in laymens terms as "signal strengh". It is simply a ratio of power that does not make it out the antenna and in turn gets blasted back into the radio. It can then damage the radio. Normally reasons that SWR is high also are the same reasons that can cause lack of reception and effective power out, but are not one and the same.
  8. PTX
    PTX "Electronically Involved"
    86
    Jan 29, 2008
    Dallas, TX
    2:1 means it is twice the "minimum value" and you want to hit the minimum value if possible.
    I'd check over on www.cbradiotalk.com those guys are real good folks.
    If you're running anything more than legal power, you don't want it much over about 1.3:1... otherwise you'll learn what a burnt final costs to replace. :biggrin_2551:
    Furthermore, it's not a measure of POWER (fwd power is measured in watts), it has to do with the amplitude of a "standing wave" ... CB uses AM, do if you had a 2:1 SWR, then only half the radio's modulation power is actually radiating from the antenna... thus it's more a measure of how efficiently the power you're generating is being used. More of less. LOL
  9. tiredtruckdriver
    tiredtruckdriver Bobtail Member
    18
    Kentucky
    Boy, if those guy's ain't about a joke....Bozo is the main joker...:biggrin_25513:
  10. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    I don't want to start a war here but the SWR stands for Standing Wave Ratio and is shown in a % or fraction on these SWR meters. If you put a 2 way Watt meter on it you would see exactly what it is doing IE FWD power verses Reflected. Thus you get the ratio. This link and chart are not the best i have seen but they explain it pretty well. http://www.firestik.com/Tech_Docs/SWRLOSS.htm
    POWER LOSS AT VARIOUS SWR
    READINGS AND RESIDUAL POWER
    Compliments of Firestik[SIZE=-1]®[/SIZE] Antenna Company Technical Support Team
    Copyright [SIZE=-1]©[/SIZE] 1996 Firestik[SIZE=-1]®[/SIZE] Antenna Company
    SWR (Standing Wave Ratio) affects the power output of your radio. The following table shows the effect of SWR for a transmitter with 4 watts of transmitted power.
    * ERP = Percentage of Effective Radiated Power SWR READING % OF LOSS ERP* WATTS AVAILABLE 1.0:1 0.0% 100.0% 4.00 1.1:1 0.2% 99.8% 3.99 1.2:1 0.8% 99.2% 3.97 1.3:1 1.7% 98.3% 3.93 1.4:1 2.8% 97.2% 3.89 1.5:1 4.0% 96.0% 3.84 1.6:1 5.3% 94.7% 3.79 1.7:1 6.7% 93.3% 3.73 1.8:1 8.2% 91.8% 3.67 2.0:1 11.1% 88.9% 3.56 2.2:1 14.1% 85.9% 3.44 2.4:1 17.0% 83.0% 3.32 2.6:1 19.8% 80.2% 3.21 3.0:1 25.0% 75.0% 3.00 4.0:1 36.0% 64.0% 2.56 5.0:1 44.4% 55.6% 2.22 6.0:1 51.0% 49.0% 1.96 7.0:1 56.3% 43.8% 1.75 8.0:1 60.5% 39.5% 1.58 9.0:1 64.0% 36.0% 1.44 10.0:1 66.9% 33.1% 1.32
  11. PTX
    86
    Jan 29, 2008
    Dallas, TX
    wow, thanks for that. I wish the table had formatted correctly, but even still, that's valuable information.
    basically, what that table says, is that if you have swr of 3:1, you are only putting 3/4 your power to the air, the rest is being absorbed within your radio. so if you have a 'stock legal' rig, that means with 3:1, you'll be only pushing 3 of your 4 watts out that antenna.
    MUD DUCK! :D
    As you can see, since it is a percentage/ratio, it gets much worse the bigger the numbers get. Try running 400w PEP thru a 3:1 SWR antenna setup, now you have your finals 'gritting their teeth' on 100w of reflected power. However, with the recommended 1.3:1 tuning, that's only 6w reflected with the same overall power.
    Bad SWR = poor signal strength and the potential to fry your gadgets
    Good SWR = good signal strength
    But neither is a measure of power, per se.
    Thanks, kd5drx.
