swr issues
Discussion in 'CB Radio Forum' started by lobes1985, Jun 14, 2014.
  1. lobes1985
    lobes1985 Medium Load Member
    306
    112
    Aug 9, 2009
    Wappingers Falls, NY
    I have a new stryker sr 655 that Im having high swr issues with. I have checked ground continuity and continuity through the co-ax with my multi-meter not resistence with either. Sometimes the swr is so high the radio goes into protect mode, other times it shows around 3, and sometimes it will start a 3 and then go down to around 1.5. Not sure what else to check to get it down
  3. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Radio is not the problem.check swrs on 40 and 1 if its high on both and about the same say 3.0 its a ground problem
  4. Ridgeline
    22,454
    117,521
    first off explain what you have as an antenna and coax, because a sometimes means a lot of different things with RF.
  5. lobes1985
    306
    112
    Aug 9, 2009
    18' Rg59 coax, cant remember who makes it, but its not truck stop brand crap. Running 2 3ft fiberglass firestik antennas mounted on the mirrors
  6. Ridgeline
    22,454
    117,521
    Dump one antenna, get coax for one antenna and start with that to simplify finding the problem.
    I am not a big fan for phased antennas on 11 meters, it seems not to make any sense.
    lobes1985 Thanks this.
  7. lobes1985
    306
    112
    Aug 9, 2009
    That's the route I'm going to go. I did get it down some. I had 2 4ft antennas that I swapped out the 3ft for. That brought it from going into protect mode down to about 3. From there I got it down to 2.1. Its difficult to tune both antennas evenly it seems.
    What recommendations for antennas do you have. I think Im going to go with a whip antenna like a Wilson or k40 because I go into areas with a lot of low tree branches and the fiberglass ones don't take the abuse very well, even with springs.
  8. Ridgeline
    22,454
    117,521
    Just use one of the 4 footers and see what happens, I would first rule out everything else then upgrade the antenna once it is fixed.
  9. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    I would recommend the whip route myself. I haul heavy equipment off road down "pig trails" on an almost daily basis, and have laid to rest quite a few fiberglass sticks. Since I switched to a Wilson Trucker 2000 (small shaft w/coil, then about 3' SS whip) I haven't had any issues. And it gets banged around quite a bit....JMHO
    Turbo-T and lobes1985 Thank this.
  10. poppapump1332
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    86 the dual antennas get one like a wilson and go from there post and let us know the results and we'll try to help you.
  11. lobes1985
    306
    112
    Aug 9, 2009
    That's my plan. Going to pick one up this week with some new coax and see how it tunes.
