SWR meter testing
Discussion in 'CB Radio Forum' started by Ridgeline, Feb 28, 2016.
  1. Ridgeline
    22,161
    113,666
    Sorry for the long winded post.
    To me cost doesn't always mean accurate.
    I have been reading about how great and accurate these expensive meters (anything over $40 is expensive to me) and I can't see it which was brought up when I was talking to my ham buddy. He was so convinced otherwise. Many of them are the same design and components used throughout the hundred of brands made through the last 50 years.
    Last week I handed a number of what I have of SWR/Power meters in my collection over to a friend who works at an RF engineering firm to test them for the bet I have with that ham. I bet this fellow ham the accuracy isn't based on costs while he claims the better meters like Dosy and Astatic are accurate because of the quality in them. We excluded thruline meters like Bird because they are not marketed for CB use.
    What is on the line is a Kenwood TS-2000 that he put up and I put up a Flex 1000.
    We agreed to use someone who isn't really into the CB/Ham scene to test meters and agree he picks out of my collection.
    For years I've bought things I shouldn't, meters are one thing I am not poor on. I have a bunch of meters like Dosys, astatic, palomar and such from the CB world that I have bought at garage, estate sales and swaps - even from craig's list postings. All to me are just barter material for more stuff - example I traded a Dosy meter for Stoner Pro 40 base, the guy was happy to get rid of that "POS" radio which just turned off on him one day - come to find out he popped the fuse in it that was too small for the radio and he didn't think to look at it. His loss, my good gain.
    So he picked out a range of meters he thinks would be a good selection. After handing over to the other guy for testing, he called both of us with results the other night.
    Out of 15 meters, the most accurate is something I got for a buck at a garage sale, a Johnson CB tester with an SWR meter and the second accurate one is an Olsen I actually bought in 1974. The newest one I got in the collection is a $130 Astatic meter which is the worst one of the bunch. That is followed by a cheap calrad meter and then a couple Dosy meters.
    He tested these with an HP test system and some jig that simulated antenna systems for the military. He tested it not just for accuracy of a 1:1 match but throughout the range. He also tested the power meter selection or in the case of multiple meters, the accuracy of the meter reading itself. Because this is informal, I didn't ask a lot of questions and don't care to - just raw results so I can win the bet.
    When I went to collect the meters, I brought him a bunch of radios with SWR meters built in, which were more of a joke, never trusted them at all. He returned them last night to me saying not one of them was even close. Those included a few "export" radios and Cobra 2000, galaxy’s and some old 23 channel Midland.
    It raised a couple questions, the first is the marketing of these meters must be really good. For some reason I run across people who have four and five in their stash, while you only need one. Is it peer pressure like it was back in the 70's - he got a cobra 142 so I have to also.
    The other is what is it worth for a anyone to have a accurate meter that is simple to work?
  3. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    That doesnt surprise me if all popular meters were tested by consumer reports or some other independent organization , with nothing to gain from the conclusion, the results would more than likely be the same. I have been using a radio shack meter for 15 years now, and it has always been accurate both for swr and power readings.
  4. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Did he say how much the meters were off? That is, were the inaccurate ones close enough to prevent damage to a radio, or would relying on an inaccurate meter potentially damage a radio?
  5. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Thanks for the great post! I've also wondered the same, but because most CB'ers are only looking for crazy high readings, or trimming the antenna for lowest SWR. (meaning I don't care if the true reading is 1.2 vs 1.35 I only want the lowest trim) I wonder can the built in meter, or cheap meter effectively find the lowest SWR regardless of its accuracy?
  6. Ridgeline
    22,161
    113,666
    Nope, didn't ask because it doesn't matter to me. It was for a bet, nothing more. I shared the results so others can see what the problems could be with wasting money in many cases.
    I don't really rely on any meter that I can't verify accurate, it is something I've come to do after years of this stuff. Bought a bunch of the harbor freight $2 meters to keep in the trucks and not one of the things showed the right voltage, they were off by as much as one volt. I know it isn't the same but standards are standards.
    Well to answer your question, yes most can, but I've had one in the past that showed weird reading on an antenna I knew was 1.3:1 for that channel, it showed higher but then on higher rations it would show lower - that one was a realistic $25 silver and black meter they had in 1979.
    However I said this before, SWR isn't the end game to antenna.
    I have to ask again what is it worth for a anyone to have a accurate meter that is simple to work?
    burnsey and TheDude1969 Thank this.
  7. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    That is why I gave away all my swr meters and bought this for $238.00[​IMG]
    The price went up $31.00 since I bought mine at DX Engineering
  8. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    A common misperception is that SWR meters measure SWR when that couldn't be further from the truth.
    An SWR meter does not measure the actual impedance of a load (the resistance and reactance), (unless two half-wavelength cables are used) but only the mismatch ratio. To measure the actual SWR of the antenna feed point regardless of cable length, an antenna analyzer or other similar RF measuring device is required.
    SWR meters simply measure and how close you are to 50 ohms regardless of resonance. Since we know that impedance changes with cable length due to reactance it is easy to see how you can fool the SWR into thinking that your antenna is resonant when it really isn't. That's where antenna analyzers come in handy because it cannot be fooled into seeng something that isn't really there because they can differentiate between impedance and SWR unlike the SWR meter which simply measures impedance as it relates to the 50 ohm baseline. Changing cable length using an SWR meter will give you different readings but changing cable length with an antenna analyzer will change absolutely nothing except for impedance but the SWR will actually remain constant. The only way to get a fairly accurate reading with an SWR meter is to use 2 half wave cable lengths as jumpers between the radio and the antenna. Any other length of cable will give you a false reading with the SWR meter.
    Reason for edit: spell check
  9. Ridgeline
    22,161
    113,666
    I've got one of them plus a couple others, what I find is that for CB work it really doesn't tell me what I need to know so I use my little VNA setup. I had an issue with coax a few years ago and the MFJ didn't show the losses in the cable, it showed there was something amiss but other than that, I had to break out the vna and use the TDR portion of it to find the problem.
    One reason I asked about what people are willing to pay, is my buddy wanted to build a couple accurate meters and see if he can market them.
    True. I ran across the work of Walt Maxwell (W2DU) who wrote a lot of articles on SWR and even a couple books (I've got one - reflections which was in my pickup and always fell out of it, I think I got a ghost in the book). Anywho, he writes about SWR and what it means to most and what it should really mean - SWR for the right reasons. The books and articles are full of a lot of info so it isn't for people who just want to put up a good rig to use but to go into depth of how to improve their antenna system.
  10. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    For $95.00 the Mfj 207 is hard to beat.[​IMG]
    burnsey Thanks this.
  11. Ridgeline
    22,161
    113,666
    Yeah but that's just an SWR meter with an oscillator driving it, nothing more. Had one for a while and traded it for something better for one of my boat anchors.
    rabbiporkchop Thanks this.
