Swr power to regulated power supply
Discussion in 'CB Radio Forum' started by ex-28, Oct 10, 2009.
  1. ex-28
    ex-28 Bobtail Member
    29
    Winnipeg, Manitoba
    i have a Dosy tc3001-p Swr meter here , it has 3 - 2 1/2" meters on it with lights , this unit comes with a power adaptor that plugs into the wall and the other end
    looks like a mono headphone jack (male) it unscrewes and there are the 2 wires + and - that are soldered onto the tip.
    i would love to run the meter lights off of my Pyramid regulated power supply bu i dont want to fry my meter lights by sending to much power to them.
    the power adaptor for the dosy meter , shows the following
    AC Adaptor
    Model: DV-1230
    input: 120 VAc 60 Hz 23W
    Output: 12vdc 300 mah
    class 2 transformer
    Pyramid Regulated DC Power Supply
    Model # pyramid PS-15KX
    -Input Rating
    Input Voltage: 105-125VAC (115V normal)
    Input Line Frequency: 60 hz
    Input Power: 250W max
    -Output Rating.
    Output Voltage:13.8VDC + 0.3v
    Output Current: 10 Amp constant / 12 amp surge
    Output Ripple: 150 mV RMS
    -Regulation
    Load Regulation: 2.5% (280mV)
    (note: input at 115vac and output at 10 amp)
    i can just unscrew the tip of the swr meter cable and solder a new cable on it to go on my power regulator , but i thnk i would need some resistors , anyone able to hel me out as to exactlly what ones i would need to add ?
    would really appreciate it , thank you
    Mike
  3. ex-28
    29
    Winnipeg, Manitoba
    fixed all working
    The wall adaptor i have have is putting out more than 12 volts i checked it , the lights just pull the amps they need regardless of how big the power supply :) so i hookedup meter lights direct to my regulator and boom all 100 %
