swr reading way too high
Discussion in 'CB Radio Forum' started by brianharrison, Dec 17, 2010.
  1. brianharrison
    brianharrison Bobtail Member
    49
    9
    Dec 5, 2010
    st augustine,fl
    i have a 29ltd cobra thats been tweeked and tuned,it does a pretty good job......or did till this morning, ive been running dual wilson 2000's on it for a while and its worked out good but all of a sudden its buzzin and the swr's are way too high(my ant lite is coming on when i key it up)nothins been bothered at all.... besides throwing it out the window and gettin a real radio like some of you are thinkin.....any suggestions??????
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    I would first check my antenna's and coax connections...Could be something as simple as a bad connection or coax...I would then take the radio to a shop and have them look at it...Least find out if it has a problem, what it would cost to fix...
    Set up right, a Cobra 29 can out-talk any of the Export 10 Meter Radios....This is why most all the guys that do the Key-Down events all use Cobra 25's and 29's and Uniden 68's and 78's...:thin:
    brianharrison Thanks this.
  4. brianharrison
    49
    9
    Dec 5, 2010
    st augustine,fl
    your right jesse, this radio has fooled a bunch of folks that think its somethin else when i tell em what it is they dont believe me... but ill check the coax and thank you again truck on...
