SWR to high, cant get it down
Discussion in 'CB Radio Forum' started by narcolepticpug, Feb 25, 2009.
  1. narcolepticpug
    narcolepticpug Bobtail Member
    11
    upland, california
    i have a cobra 25, 5' antenna, on a f250 4x4.
    the antenna worked fine on my cobra 19 ultra, but i broke the thing trying to put a power swing on it, so i went out and got a realy radio. but when i hooked it up the swr was at like 3.5:1. i tried ground out everything on my truck and only got little change. the only thing i can think it might be is i have a cheap coax from radio shack. but i dont know if that could be it cuz it worked fine for my other radio. whats wrong, anyone know??
  3. LandShark
    LandShark Road Train Member
    1,525
    1,064
    Nov 22, 2008
    Riverdale, Ga
    if running an 18 ft coaxel try a 12 ft one..18fters will give you a false swr reading. at least thats what of few radio shops have told me.
  4. narcolepticpug
    11
    upland, california
    i hooked up my swr meter and it gives me a diffrent reading than the swr meter in my radio.. witch one should i go by?
  5. arky870
    arky870 Light Load Member
    98
    26
    Nov 5, 2008
    moulton,al
    you have a cobra 25 with an swr meter?an external meter is almost always better than an internal one.they are good for getting it fairly close but i wouldn't trust them much.i didn't think 25's had swr meter though.
  6. narcolepticpug
    11
    upland, california
    sorry thats a typo, i have the cobra 29 ltd Classic
  7. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    If you are useing the radio SWR meter quit use the external meter it will be more acurate
  8. squirrellsgnwild
    squirrellsgnwild Medium Load Member
    what antenna is it and how is it setup?
  9. narcolepticpug
    11
    upland, california
    well now im down to 1.3:1 on all chanels on my meter in the radio and the external. why? i have no idea. but it only does that when the jumper cable and external meter are hooked up. as soon as i disconect the external meter, the radios meter jumps back to 3.5:1. so im just going to leave it all hooked up, and im golden.
    thank you all for your respons
  10. Red Fox
    Red Fox Road Train Member
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    You don't have your coax coiled up in a neat roll do ya?
    That's a BAD thing.
  11. narcolepticpug
    11
    upland, california
    i did, but i red that it chokes it so i fixed that....
    my swr is low now, but when i key up, as soon as i start to talk my ant light comes on. why is that????
