Symptoms of a bad VGT
Discussion in 'Volvo Forum' started by Socal Xpress, May 15, 2016.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    630 d13 691k 10speed
    Last night I got a code mid 128 pid 27 fmi 7. I don't notice any power lose. What can I check to narrow down the problem?
  3. Movingismylifeilovemoving
    Movingismylifeilovemoving Light Load Member
    230
    292
    Aug 5, 2015
    I just went through this. Symptoms would be only 1 stage on your jake/retarder, the turbo doesn't make the same spund at idle, and tirbo takes longer to spool. You'll notice it more in lower gears. Bad news is your turbo probably needs to be replaced. If its just the actuator its $1000 to replace but often its coking on the vanes that ruin the actuator. I just paid 6 grand for a new turbo. I drove about 5000 miles after it went out snd it ran just fine.
    Dave_in_AZ and Socal Xpress Thank this.
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
  5. UltraZero
    UltraZero Medium Load Member
    406
    96
    Jul 18, 2013
    What year truck did you have the turbo replaced.
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Moving has a 2011 d13.
  7. boyanb
    boyanb Bobtail Member
    12
    Chicago
    I have a similar problem with my Volvo Vnl 780 D13 2011 truck that has mysterious problems that nobody can resolve.
    Truck simply stalls and loses the boost periodically and to a point that is impossible to drive. After many fuel filter changes and many trips to dealer and various repair shops nobody knows what it is. Not to mention truck has no codes on the dashboard. However with the Techtool I was able to detect some codes for J communication line that truck had. Any help is appreciated.
