T/A Richmond Hill Ga
Discussion in 'Truck Stops' started by passingthru69, Oct 29, 2012.
  1. passingthru69
    Well here's my fun filled day at the shop here.
    Go in and ask about getting some wiring fixed and dot insp on the trl.
    That was at 9:30 this morning.. Ok pull it over the pit as I have a lowboy trl.
    I tell the tech. where the wiring issue is. Ok no problem. Well then he tells me I need to stretch the trl. s he thinks it's in one of jcts. there.
    Well after 5 hours he then tells me to pull into the other bay for the insp. and replacing the wheel seal that is leaking. I did not catch that.
    Well here it is 9:30 at night and he's still trying to do the wheel seal. I told the shop service writer.
    i'm dropping the trl. and will see you in the morning when I wake up..
    Pulled the king pin and have it with me. almost 11 hours and they still are screwing with it....
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    they making the wheel seal by hand? Lordy, most shops took about 30-45 min for a wheel seal.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    i'd be lookin at the final bill real hard before payin!
  5. passingthru69
    Well I got the trl. out of the shop this morning.
    Said they got it done about mid night.
    I was sleeping then.
    they had to go get a wheel seal. No charge for that as they were out of stock.
    They put on a new brake drum. I'm like huh? Well it had oil on the drum, well you should of cleaned the other drum as they were all replaced in July this year.. Company is fighting them on that now..
    Wheel seal job was flat rate, so the "tech" kinda ate that one for being slow.
    The wiring, they put in 8 hours. I questioned that as there were times he was just standing around.
    Yes I know wiring can be easy or a pain.. been there done that.
  6. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    8 hours??? They could have rewired the complete trailer in 8 friggin' hours>expecially a rgn/float that was over a pit!
  7. passingthru69
    Yep, seeing how trail king is what I call a plug and play system.. I could of had the company order a new harness and had it shipped and had them install it, instead of him cutting and splicing wires. This will cause more headaches later.
    I asked our road service dept. about this today.
    They said this trl. has had much wiring issues. I hinted at a new harness while I'm off on home time in Dec.
    They are thinking about that now.
  8. drvrtech77
    drvrtech77 Road Train Member
    15,139
    147,067
    Mar 20, 2010
    TA technicians get paid hourly + comission.
