t2000 c15 acert 07
Discussion in 'Kenworth Forum' started by lady doe, Aug 3, 2014.
  1. lady doe
    lady doe Light Load Member
    72
    4
    May 25, 2014
    had a over head done.and jake brake worked fine. Then had some actuator put and wires. But here is the kicker. My jakes dont work anymore only half work. Can someone help me out here.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Ck. switch 1st to be sure it is putting power to all jakes?
    lady doe Thanks this.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,115
    May 19, 2011
    What is this supposed to mean? You then had some actuators replaced, and wires?
  5. rank
    rank Road Train Member
    9,918
    113,501
    Feb 11, 2010
    They must have disconnected one of the wires under the rocker cover when they were in there adjusting the valves and jakes. I mean if it worked fine when you took it there and then it didn't just go back no?
