T2000 turning radius
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Displaced Yooper, Feb 4, 2012.
  1. Displaced Yooper
    Displaced Yooper Light Load Member
    152
    49
    Oct 18, 2010
    Detroit, MI
    Does anyone know of a way to improve the turning radius on a T2000?
    I suspect that the stops in the P/S box are the culprit, but have no clue if something can be done.
    Turning the steering wheel to full lock either way barely gets the steers to what looks to maybe be a 30 degree angle, if that. My old W900 with a 270 inch wheelbase turned tighter than this truck with a 244 w/b.
    I'll explain what the problem is to me... If I'm backing into a tight spot, and I get my trailer at a 90 degree angle (L-shape) to the truck, I cannot just turn the wheel to the lock & get the truck straightened out again, I HAVE to do a pull up. With my W9, I could just turn the wheel, & the truck would swing right back in front of the trailer.
    Is there a way to adjust or eliminate the stops in the steering box? Maybe a different box I could replace it with that would allow more movement of the steers?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    we tried to do it with trw box and with 315/70R22.5 tires they touch frame, so it is possible with 295/70R22.5 ore with 275/80R22.5 tires
    Displaced Yooper Thanks this.
  4. Displaced Yooper
    152
    49
    Oct 18, 2010
    Detroit, MI
    Thanks Pablo,
    Do you have the part # for that TRW steering box?
  5. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    Most steering boxes have auto set poppet valves that are set initially when the truck is built. What sets the poppete is the steering stops in the spindles making contact with the axle beam. If the poppets are properly set there should be about 1/4" gap between the stop and axle when the gear runs out of power assist. Turn the wheels all the way and check the clearance between the stops and axle. Sometimes they just aren't set properly and the gap is too big, meaning you do have more wheel cut room available. To set them all you do is jack up the axle and turn all the way until the stops make contact with the axle. If they are already making contact those stops are adjustable. You can screw them in to make a tighter wheel cut. You have to watch for how much clearance your tires have with inner fender, drag links, shocks or whatever. If you make any adjustments make small ones because those auto poppets are hard to reset if you go too far.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    often times the bolts that act as steering stops may not be set right. I have driven 2 different trucks of the same model, specs and wheelbase that turned differently. Turning in the steering stops by only a couple of threads can make a world of difference, but make sure everything has clearance.
  7. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    Don't know about the T2000, but Kenworth had a bulletin on adjusting the stops on the T800s, and W900s. People were screwing them in so far that it was causing the frame rails to crack near the spring hangers. I have turned them in on every Kenworth I've owned, sometimes it helped, sometimes the "stop" was somewhere else. Was lucky enough not to crack any rails, but know of two W9 owners that were not so lucky.
