T2000 with CAT 3406E, cranks over but will not start
Discussion in 'Kenworth Forum' started by whskypete, Jul 18, 2014.
  1. whskypete
    whskypete Bobtail Member
    28
    Sep 17, 2013
    Kenworth T2000 with a CAT 3406E, cranks over but will not start. If you add starting fluid it will burn up the fluid but will not maintain idle. Fuel does reach the head but something will not allow the injectors to activate and work. Does anyone have some wiring ideas as to which pins need to be checked? Or where to start?
    Thank you
  3. Mooose
    Mooose Light Load Member
    161
    61
    Apr 13, 2014
    Sherwood Park,AB
    Check ECM fuse
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    If its not showing a code the sensor on L ft. of timing cover or the one lower down on the crank sensor on L side might be the problem ENG. will do just as yours is doing, carrying a extra one in the tool box is like having a spare set of points in a old car! 137$ last one I paid for.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    if not electronic it could be a fuel pressure issue. either check valve or transferpump or plugged filter. you can have pressure but if it isn't enough the injectors wont fire.
  6. Mooose
    161
    61
    Apr 13, 2014
    Sherwood Park,AB
    If the ECM fuse is blown or a bad connection to the battery it will appear normal, crank over and everything but will not fire. I've had it happen, the tech had the engine firing with starting juice but as soon as you stop the engine quit running.
  7. turnanburn
    turnanburn Medium Load Member
    628
    270
    Jan 25, 2011
    central Vermont
    Ditto on that. I had the same symptoms--problem was bad connection on the ecm fuse @ the batteries.
