Rear t/signals and flashers work fine but the front turn signals and flashers( hazards ) are not working at all !!!! Help please!!!!
T600 issues with turn signals
Discussion in 'Kenworth Forum' started by Factransport, Jul 16, 2013.
if i had to guess. it would be the turn signal switch. or broken wire(s). between the switch and front turns.
if it's possible to have 2 flasher relays. maybe one of those also.
i had a w9 that wouldn't work when the trailer was unplugged. no turns or flashers. the turn switch itself had a bad ground connection. -
Thanks for the ideas, ill have to check the quantity of relays, also I don't have a trailer hooked up now but ill go and hook and try tha.
Only one flasher relay. It is more than likely a ground issue. I had problems last year with my 03 t600, headlights & turns were acting up. It was a ground wire in the dash.
Ground wire from the t/s switch?
