T660 electrical gremlins after batteries changed
Discussion in 'Kenworth Forum' started by Gunner75, Jun 4, 2018.
  1. Gunner75
    Gunner75 Road Train Member
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    Friday we changed all 4 batteries after checking that 2 were bad, and had slight leaks. This morning while deadheading to my shipper everything was fine, i shutdown to get loaded, then started the truck to pull forward and my voltmeter on the dash was reading 16.3volts. I informed my company shop, they said to run with it till i shutdown for the night and call them to have someone come check it out. I dont even get 2 miles away and i lose all my dash lights, headlights, turn signals, speedo, and tachometer. I pull off and check all my alternator and batteries and everything is tight. I restart the truck and everything is lit back up and working fine, except for my voltmeter on the dash. Driving another 5 miles and the same thing happens. Lost everything on the dash and no outside lights. Shop decides that i should drop my trailer and head to the kw dealer on the north side of lima oh.
    Interesting tidbit....
    As i bobtail over to the dealer, the voltmeter is reading 14.1v and the lights and all are working....im at a loss and so is my shop, hopefully this kw dealer can make heads or tails
  3. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    First thing I would do is plug it back into the trailer.
  4. Gunner75
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    Got over here to the shop and the shop here says that the alternator (which is on only 3 months old) is the problem. Not sure what is wrong as they spoke with my manager. They did check all the connections, and couldnt find anything till they tried testing the alternator under a load, then they started to hear "noise" from inside the alternator body
  5. Trucking in Tennessee
    3,740
    5,740
    Mar 19, 2018
    Nashville
    Guy I know chased electrical in a T700 to the tune of $14K. Good luck.
  6. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Had a very similar incident several years ago. Turned out the person who replaced my batteries hooked up a cable or 2 wrong.
    You said they checked the connections though.
  7. pushbroom
    pushbroom Road Train Member
    1,779
    7,312
    Sep 1, 2012
    When an alternator starts to overcharge, it puts too high of a voltage to the CECU and the CECU turns off, hence the entire dash loosing power. Replacing the alternator should fix it up. We were having an issue with aftermarket alternators doing this but factory ones will not. On one truck I even ran new alt cables and a signal cable to an aftermarket alternator and still could not make it work. Swapped on a factory alternator, works excellent.
    This does not happen to all trucks, just a couple of them.
    389driver and Gunner75 Thank this.
  8. Gunner75
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    And that was exactly what was happening. After the swap i was able to run for another hour and a half before shutting down and didnt have an issue at all.
    blairandgretchen Thanks this.
