T660 gauges quit working only RPM and speedometer work.... keeps blowing the cecu pwr fuse
Discussion in 'Kenworth Forum' started by Pakeezy, May 10, 2016.
  1. Pakeezy
    Pakeezy Bobtail Member
    May 10, 2016
    So yesterday I stopped to get fuel shut the turn off turned it back on and parked it for my 10 hours went to the sleeper to get my things ready for a shower when I was going to shut the truck off I notice my gauges weren't operating.
    had the following symptoms
    Dash lights come on the speedometer and rpm gauge, rpm do show correctly when running
    All others gauges no lights or no function
    Gauges did not cycle when key turned on
    Info screen above the speedo and rpm gauge worked but the select wheel would not change the information
    On roll F there is 2 cecu pwr 15 a fuses side by side to the far right my truck keeps blowing the right one.
    Another thing I've noticed was the relay IGN BUS RELAY and the ACCOUNT BUS RELAY where warmer than all other fuses.
    This morning I took the dash apart looking to see if there was maybe a lose wire but didn't see any.
    Any information would be much appreciated.
    Reason for edit: miss spell top to took
    x1Heavy Thanks this.
  3. Misfittruckingltd
    Misfittruckingltd Bobtail Member
    8
    Did you find your problem? I'm having the same issue
  4. T660 TX81
    T660 TX81 Bobtail Member
    Did you find the problem having the same issue
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    Your harness has been working too hard, all hot and bothered. You did more than 90% of dimwit drivers will... touching them to see if it hurts or not.
    The 90% of dimwits will just take the RPM and Speedo as the two main gauges needed to run the big truck, all the rest of it is hooey and BS to them. IF they are particularly slow in orientation, a smart company cookie will paint primary bright coloers on the tach to help them out.
  6. AModelCat
    161,291
    If you're blowing a fuse immediately, the wire coming off that fuse or something attached to that circuit after the fuse is grounded out or shorted. Or someone added in an extra accessory to that circuit that the wiring can't handle.
    (In response to the recent post, not the ones from 2016)
