T680 keeps blowing fuses
Discussion in 'Kenworth Forum' started by antoinefinch, Nov 22, 2015.
  1. antoinefinch
    antoinefinch Light Load Member
    187
    120
    Jan 23, 2015
    Phenix City, Alabama
    The 2014 Kenworth T680 I drive has blown every lighter fuse I put in.the sleeper lighters and the cabin lighters keep blowing?Now my Performance Center and Radio won't work along with the lights on my oil and trans guages,I can't locate the fuse for them any ideas or suggestions would be appreciated
  3. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,522
    May 28, 2015
    There should be the common panel at your left foot on the floor at the firewall. There's probably another under the hood. Possibly another in the sideboard or under the bunk.
    If you keep blowing the same fuse you either are overloading that circuit.. have a pinched or skinned wire somewhere. . or have a ground problem. I doubt it's a ground problem because the fuse won't blow without current travel and it won't travel at all without a ground.
    This could be a relay problem , also. Not a fuse.
  4. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    Also could be yet another panel behind the glovebox....
  5. DUNE-T
    DUNE-T Road Train Member
    6,943
    16,843
    May 10, 2015
    Detroit, MI
    On my older Volvo the problem was in the red light at the bottom of the door, opened it up and could see right away bad connections
  6. JRBES
    JRBES Bobtail Member
    17
    4
    Jun 22, 2015
    Once you find the fuse disconnect everything that fuse powers. Plug one at a time that will narrow your search that is shorting you out
