T680 marker lights interrupter inoperable
Discussion in 'Experienced Truckers' Advice' started by Cowboy2, Apr 11, 2022.
  1. Cowboy2
    Cowboy2 Bobtail Member
    9
    Apr 11, 2022
    Texas
    Good afternoon,
    I am hoping someone can help. The button on the turn signal, to flash your taillights as a thank you and when my headlights are off you can typically flash your high beams does not work as well. I also noticed the two front marker lights on the trailer do not work. This has been on 3 trailers, so assume it is something with the truck. I checked all 3 fuse boxes and pulled anything marked lights and they are all fine. I suspect a possible relay. Any thoughts or suggestions would be appreciated.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    Light cord plug is what I would check first . Normally I have a old spare that works so I use that to check.
  4. Cowboy2
    9
    Apr 11, 2022
    Texas
    Thank you. I tried cleaning the light cord inserts with a brush. I’ll try another cable as well. I appreciate your advice
  5. mustang190
    mustang190 Road Train Member
    2,872
    6,180
    Jan 18, 2011
    Florida Panhandle
    T680’s have a ton of electrical problems.
  6. Oxbow
    Oxbow Road Train Member
    13,350
    138,292
    Nov 24, 2015
    It kind of sounds like your switch for either the black or brown wire isn't turned on (clps-marker lights) if you have pulled multiple trailers and some of the marker lights aren't lighting up, but I have never been in a T680 so I don't have any idea of your switches.
  7. Cowboy2
    9
    Apr 11, 2022
    Texas
    Thank you for your reply. Yes I have 3 light rocker switches and all are on. Next time I get it services I’ll see if the shop can figure it out.
    Oxbow Thanks this.
  8. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    If it weren't for constant electrical issues, my T680 wouldn't have issues, I swear these trucks were wired by 3 yr olds and the numnuts at KW aren't any better when it comes to fixing the stuff
  9. Mr.Stingray
    Mr.Stingray Bobtail Member
    It can be the subframe harness
  10. snowwy
    snowwy Road Train Member
    20,591
    13,309
    Jul 6, 2009
    Since ALL the lights blink..the problem won't be the trailer.
    And it's not confined to the 680. I had the problem in a w900.
