t680 winter front
Discussion in 'Kenworth Forum' started by haywire12, Nov 20, 2014.
  1. haywire12
    haywire12 Light Load Member
    297
    97
    Dec 20, 2011
    Ontario, Ca
    I was wondering if anyone has found any of the winter front for these trucks or anyone know the best way to make one that would work for these trucks.
  3. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,269
    44,357
    Jul 23, 2007
    Midwest
    Have you check with a KW Dealer/Shop? I made one for my husbands FLD, and apparently it was so cool, someone stole it. :biggrin_25524:
    rollin coal Thanks this.
  4. Kenworth #1
    Kenworth #1 Light Load Member
    102
    71
    Aug 16, 2014
    Clarksville,TN
    Check manufacturer recommendations. Most of the newer trucks don't need them. I have a 2012 T-700 ISX15. I have plenty of heat without a winter front. And temp stays at 185*. With the new emissions a winter front can actually cause problems.
    The Challenger and magoo68 Thank this.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I politely disagreed with salesman about his stating a winter front wasn't needed ... He brought me to the head mechanic who stated that t680 owners using a winter front are seeing more engine derates due to high intake temperatures ... I'm still on the fence but have noticed in minus 20 my temps are still up in normal range .. Only issue seems a bit longer warmup time .. At 1000 rpm it holds 200 no problem so far the few times I idle
    Kenworth #1 Thanks this.
  6. 350xj
    350xj Bobtail Member
    8
    Mar 14, 2011
    dan_0092@hotmail.com
    Call great west kenworth in calgary ab I just got one ordered today they said they work great and jight quality to +1 (403) 253-7555 here's the number for them.
  7. Kenworth #1
    102
    71
    Aug 16, 2014
    Clarksville,TN
    I also heard that there is a temperature sensor located near the front of the engine that activates the heater on the DEF tank and lines. With a winter front, it blocks the air flow to that sensor and the DEF will freeze which will set off a malfunction light and eventual engine derate.
    magoo68 Thanks this.
