T700 A Few Sensor Issues
Discussion in 'Kenworth Forum' started by Truckboss, Sep 19, 2019.
  1. Truckboss
    Truckboss Bobtail Member
    2011 T700 w/ Paccar MX 13
    P102A = Temperature after BPV - Voltage too high or short circuit to supply on ECU (D420) pin (C11)
    Not sure about this one? When is this temp sensor located?
    P0107 = Boost pressure sensor F802 - ECU pin A51 signal voltage too low
    Thinking bad wiring on sensor here or bad sensor, should be an fix. Can I clean this sensor since it gets soot on it?
    P3841 = Air shutoff valve - Stuck in closed position
    This one is related to this:
    Air Shutoff Valve Short To Ground Or Open Circuit On ECU Pin A32
    Possible causes:
    1) The air shutoff valve fails to open.
    I am thinking it is the valve with the banjo bolt, is that correct?
    I have this project on deck for tomorrow. Any help or suggestions would be greatly appreciated.
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    All I know is there are some sensors on that truck that are made poorly and fail often. But perhaps they are updated now. Or I may be thinking of Cummins, not sure if the same sensors are on the MX.
