T700 Mirror broken
Discussion in 'Kenworth Forum' started by Jerzey, May 10, 2018.
  1. Jerzey
    Jerzey Bobtail Member
    15
    Jun 19, 2016
    Hello All
    I have a 2011 T700. The main mirror (upper glass mirror) on my passenger side is damaged. Is there a replacement for just that part? I’ve seen them for the T660 but not the T700. Thanks for the help.
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    I'm sure you can get the replacement at a KW Stealership.
    Call the Stealership and get the part# and Google it, You may find it less expensive elsewhere.
    From what I can tell, the mirror looks the same as a T2000, but I would contact the Stealership to confirm that.
    Unfortunately, the T700 was a stop gap created to fill in the line up before the successful all new T680 was introduced, so aftermarket parts and accessories are limited as manufacturers didn't want to invest in a truck model with a short lifespan.
  4. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    I'm pretty sure that it is available as a separate part, but I can't promise you that it'll be kept in stock. I seem to recall having replaced a couple when Navajo ran a small number of them.
    Might have to look a little further and wider than the dealership to find it, though. Chances are, if KW does have it, they'll try to push you into buying the whole mirror assembly so they can get it out of inventory.
  5. Jerzey
    15
    Jun 19, 2016
    Thanks for help guys! I got it from the dealership for $100.00. Being that I needed it ASAP I just went ahead and purchased it. Thanks again!
    WitchingHour Thanks this.
