T800 13" to 15" aircleaner help
Discussion in 'Kenworth Forum' started by C15Mike, Apr 20, 2019.
  1. C15Mike
    C15Mike Light Load Member
    54
    27
    Sep 15, 2016
    I have a 08 t800 with a tuned C15 SDP engine in my tri-axle dump truck putting out 630hp. When I pull a hill loaded at about 80,000lbs the 13" donaldson style air cleaners are extremely loud like they can't pull enough air and my air cleaner restriction gauge spikes to almost 10 inches of vacuum. Does anyone know if the 13's could be restricting the engine and if so would 15's off a W900 fit the T800 or would anyone know the part numbers I would need to run the 15's? Any help is greatly appreciated. Thanks
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Why not go to a Fleet Air Filter, I think that would solve your problem.
  4. wore out
    wore out Numbered Classic
    16,052
    194,360
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Thing with a fleet air filter is the only way to flow more air is open the micron rating up. For a dump that is on quarry haul roads that isn't the best thing.
    As far as the air flow from 13 inch cans to 15 inch cans I can't see there being a big difference.
    spsauerland Thanks this.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    I have went the opposite way putting 13 in place of 15. Called technical support with Donaldson and they said would be fine and that CFM rates are very similar. 10 in of H20 isn't high. Converted a 05 W900S C13 to single turbo and it screams thru the breathers, but been that way for about five years now with no issues.
    wore out Thanks this.
  6. C15Mike
    54
    27
    Sep 15, 2016
    Ok great I appreciate all the help guys!
  7. t8003406e
    t8003406e Bobtail Member
    Hey did u sort out this problem. I have a 04 t800 only came with one air cleaner. I’m looking to install the other one on the driver side but I’m not sure if the 15” from the W900 will fit. Apparently these are really hard to get and I found a scrap yard with these two sitting around.
  8. abyliks
    abyliks Road Train Member
    3,913
    9,156
    May 2, 2010
    ludlow MA
    Mirror brackets are different from 13”-15”,
    anything will fit with enough time, tools, and money, changing the air filter more often seems a lot easier
