T800 lighting issue
Discussion in 'Kenworth Forum' started by texmechanic, Jan 4, 2014.
  1. texmechanic
    texmechanic Bobtail Member
    2012 t800 have rear turn signals on tractor and trailer but no torn signals on the hood, i have power to lights just no turn signals. fuses and real are good. any one else have this problem or advice on fixing it
  3. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Have you first checked the bulbs in those two signals?
    Not likely two would ail at once, but it is possible the passenger side one went out unnoticed awhile back, and now the driver's side one went out.
    Just a thought.
    If bulbs are ok, I'd focus next on the feedthru connection at the firewall.
  4. texmechanic
    put new lights on to elimante that problem and replaced the relay behind clutch pedal lights in cab work showing signals are flashing, i do have power down black wire on light that is the side marker, no power on red wire which powers the blinker i have tried with just 4 way switch on and had no power up front rear works fine and used blinker switch still have power to rear still no front and dash lights still work
  5. wore out
    wore out Numbered Classic
    15,845
    191,670
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Could be your signal stat switch. Usually when they start to go bad you will have blinkers on back but no break lights. The diode that seperates front and rear is in it. Most of the time you can turn blinker on an wiggle handle around with steady pressure and find a sweet spot to make it work thus verifying your problem. Also look at flat 4 wire connectors where the hood rolls on hinges in the front I have seen lots of corrosion there, and at firewall on driver outside where all the outside harnesses plug in.
  6. Woodysawzall
    Woodysawzall Bobtail Member
    Did you ever find your problem? I have turn signals working everywhere but on the hood. The Ground is not a problem,got good ground. Very unusual to lose both left and right and only on the hood, otherwise I would suspect a rotten wire.
