t800 trans
Discussion in 'Ask An Owner Operator' started by gyayo2012, Feb 25, 2014.
  1. gyayo2012
    gyayo2012 Bobtail Member
    12
    Sep 26, 2011
    acushnet
    Hey everyone i have a 94 kw t800 truck has 4.56 gears with an eaton super 10 speed trans it.. i have a love hate relation with the trans but the clutch is on its way out so was thinking od putting a new tran in it.. does anyone have any recomendations as to what to install dont know if i will be able to dump an 18 speed in it due to the 4.56 gears or if im better off staying 10 speed or eben droping to an 8 speed.. any info would be greqatly appreciated
    Thanks
  3. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    I'm guessing this is a dump or some other type of vocational truck? If you do a lot of off-roading, you could benefit from an 18 speed. But you'll probably have to replace the driveshaft, as the 18 speed will have more length to it, due to the additional auxiliary box. Same thing if you go to an 8LL. It all really comes down to how much money you're willing to sink into it... for a 20 year old truck, that's a substantial amount you're looking at.
  4. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Don't forget they wont trade you a 10 for an 18 either at the rebuilder / seller. And he's right, need to cut the shaft. Watch your torque too, make sure you get the same rating as what comes out.
    And of course my usual preach......."Don't got to the commode without paper" which means get the rear main seal, pilot bearing, if Detroit check that cam seal, flywheel, linkage and cables plus U joints....anything between the engine and rears get evaluated.
    JMO
  5. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    didn't you say super 10? there's a small difference in leingth. the 18 speed has the same OD as the super 10. 18 just has a better low, 14-1 instead of 12-1in the S10. reality though if you're not going to haul 80,000 pounds plus you won't ever need anything more than 8LL.
