tach output wire
Discussion in 'Peterbilt Forum' started by 99pete379, Dec 23, 2013.
The tach is ran off a two wire sensor screwed into the rear structure of the engine. Reads off the flywheel teeth. It could be on either right or left side, about the 5 or 7 o'clock position. I was thinking usually right side on that one.
Oxbow Thanks this. -
K thanks ill look for it there
We are having the same trouble for the same reason. Ours is an '06 though and has the plugs with the pins. Any thoughts?
