Tail bone
Discussion in 'Driver Health' started by stabob, Jan 25, 2013.
  1. stabob
    stabob Heavy Load Member
    862
    483
    May 25, 2011
    Sebring Fl
    Has anyone had the problem that Im having? Ive lost alot of weight 258 down to 180 now and the last week or so I can hardly do my job I feel like Im sitting right on my tailbone and it hurts alot! And I mean alot I had to come home today and take off the thoght of one more hour in that seat was just to much. Oh and I lost the weight the proper way 1 to 2 lbs a week over a 7 months time span with a good diet and running two miles a day. Im not to thin I was 160 to 170 all my life till ten years ago when I started this job. I hope my body gets used to it soon!
    Chinatown Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    76,873
    179,304
    Aug 28, 2011
    Henderson, NV & Orient
    You need a pillow, called a donut. It's round with a hole in the middle, thus "donut." You can make one out of sturdy foam with a hole in it about the size of a normal sized coffee cup..or buy one at a hospital or Walmart. Sit on it so the tip of the spine/tailbone in on the hole. Make sure the donut is thick enough so that when you sit on it, the tailbone doesn't touch the seat. Always use this and you will be OK in a few days.
    stabob and Bayle Thank this.
  4. stabob
    862
    483
    May 25, 2011
    Sebring Fl
    Thanks I cant believe I did not think about that!
    x1Heavy and Chinatown Thank this.
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    I always used a pillow,,, I have a frac L-4 that is healed and long periods in a seat that is straight up kills me... a pillow really helps.
    Also try moving your seat around, up/down so you are not sitting in one position for long periods.
    x1Heavy, Chinatown and stabob Thank this.
  6. Chinatown
    76,873
    179,304
    Aug 28, 2011
    Never carry a wallet in your back pocket while driving; it puts uneven pressure on the spine and causes the spine to curve sideways.
  7. Chinatown
    76,873
    179,304
    Aug 28, 2011
    Did you try the donut pillow?
  8. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,416
    Jan 19, 2008
    Berea, KY
    Wow, i was blaming genetics for that.....
  9. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    If you pull a dry van your wallet shouldn't be an issue.
    Sent from my RM-845_nam_vzw_100 using Board Express
  10. SteelTownClown
    SteelTownClown Bobtail Member
    5
    Jul 28, 2019
    Pennsylvania
    SHOTS FIRED!!! HAHAHA!
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    I would hate to think the total failure of my spine is off that chain drive wallet I wore since 15 and am still wearing.
    Regarding the doughnut I thought it was necessary to consume food until you built up enough bulk to take a seat without the ow.
