Tail light issue 2011 T800
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mn logger, Dec 6, 2014.
  1. Mn logger
    Mn logger Bobtail Member
    4
    Northern MN
    Was wondering if anyone could shed some light on my intermittent tail lights on my 2011 Kenworth T800???? It has been going on for a couple weeks now, brake lights and signals work perfectly. Sometimes they work but most times not. Spent several hours tracing and checking wires and came up with nothing. Appreciate any ideas you my have.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    I would run a new wire from the firewall to the taillights.
    If the problem is gone,you have either a wireharness that is rubbing somewhere or a broken wire.
    If you don't find a harness with damage,i would let the new wire become the longterm solution.
  4. Mn logger
    4
    Northern MN
    Thanks. I was kinda holding that as a last resort,but if it comes to it I'll do it. Thought they're might be a harness plug faulty or something else. These new trucks are so complex it makes my head spin!
  5. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    The black ground is running lights. Blinkers and brakes work without the black one.
    So brake lights and signals always work? Or not always?
  6. Mn logger
    4
    Northern MN
    Yes blinkers and brake lights work perfectly all the time. The tail lights just come and go, when they do work they work well. Just not getting any power from up the harness when it's not.
  7. Pool6710
    662
    258
    Aug 10, 2014
    Minnesnowta
    Does this also effect the rear plate light?
  8. Mn logger
    4
    Northern MN
    I have removed the plate light, but no there is no power there also.
