Tailswing
Discussion in 'Questions From New Drivers' started by RayBlaszak, Jan 14, 2019.
  1. RayBlaszak
    RayBlaszak Light Load Member
    208
    146
    Aug 20, 2015
    When turning around at a shipper that has just enough room what's the best way to turn around while being mindful of your tailswing? Basically, what's the best way to turn around when your only option is to jackknife and turn around. Went to a place today and they load dryvan and flatbed at the same time. I wasnt able to go out the entrance because it was blocked. Also I didnt want to block others so I went the other way to turn around. Luckily, I didnt do any damage but the back end of my trailer was about 1CM from destroying a lot of their product. I normally try to avoid these maneuvers on my blind side but had no choice. Is there a way to guesstimate how much your tail is actually going to swing?
    Rideandrepair Thanks this.
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    No hard and fast way to know. Just have to be aware and know that the more you have tandems slid up, the further the tail will swing out. So try and leave a bit of additional distance along the side you’ll be turning away from. If in doubt, do about a quarter to half of your turn, stop and go see what’s going on and if you’re getting too close.
    But 53’s and the tandems all the way back are more prone to making contact with the back of the cab in hard u-turns.
    BigDog Trucker and Rideandrepair Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    I once destroyed 15K in home depot inventory (Trailers) due to being trapped in a tight spot. Made the circle itself with the tractor with a foot to spare but the other end did the damage. There is no point in getting into the particulars leading up to this problem.
    There is one type of turning that most people don't consider often. (I should have, however due to the overall situation you have a hard time remembering obscure solutions when youe stressed.)
    That is to drop the trailer, come around with the bobtail to where you hook onto it from the side directly to the kingpin. The problem with that is the trailer is such a fragile thing you can totally wreck it all doing that. You would essentially be able to then spin in place eliminating the bobtail's turning radius. It really depends on the overall situation.
    Most of the time it's chain link fence that got into my way up in the north east. It is not difficult to put the cabover tractor against it and add power gently. Mash it a little bit and get that extra three feet of pull up to make it work. I don't recommend that today in this world of surveillance everywhere.
    Yes there have been times that overhang had done damage and alot of that. we were not fired because the situation that led up to that was the fault of the store management directly.
    Schoob and Rideandrepair Thank this.
  5. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    When in doubt get out and look.
    x1Heavy, ncmickey, Tb0n3 and 4 others Thank this.
  6. Rideandrepair
    17,526
    56,785
    Aug 8, 2015
    Jack it around, don’t let it hit the Cab, put some flat spots on those tires, when You see them turning in a reverse direction, your jacking it just right. Seriously get out and look when in doubt. Others will respect this, especially the Owners of property possibly damaged. Best thing to do is swing wider than needed then straighten wheel, then back up jacking it, watching rear of trailer and front then finish u turn.
    Schoob Thanks this.
  7. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Otherwise learn to back it what ever distance and then you can drive out.
  8. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    The backside docks of Wakefern Foods. Woodbridge, NJ with a mostly full set of docks. I hated those meat docks way at the end.
  9. dedwarmo
    dedwarmo Bobtail Member
    8
    9
    Apr 19, 2013
    You always have a choice. If you set the brakes and turn off your truck you will do Zero damage. How long would you have had to wait until the entrance is no longer blocked? What was blocking the entrance? Another truck? Did you speak to the driver? A fork lift? Did you speak to the forklift operator? A dropped trailer? Was there a yard jockey moving trailers around? Could you have moved the trailer yourself? A pallet? Was there a forklift operator that could move it for you?
    Did you speak to anyone inside about the blocked entrance?
    None of us were there, so we don't know what other options were available to you.
    One thing I've learned the hard way is not to drive into a place that I can't get myself out of. Sometimes the only way out is to back out blind onto a street. Not fun or safe. Get help if you can. Put out flares or triangles. Get out and look.
  10. dedwarmo
    8
    9
    Apr 19, 2013
    1. Get out and look.
    2. Move the truck a few feet.
    3. Repeat
    Rideandrepair and buddyd157 Thank this.
  11. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    i have at least 2 stops in downtown Boston, each night. then i have a stop north of there. as a result, i have my tandems on my 53' all the way forward, to get around telephone and light poles, and squeeze in between traffic islands and cars parked to one side. don't get me started on unannounced pop up construction jobs many times.
    it gets hairy, but i have to know where my trailer is at all times.
    at one of my stops, especially during the winter, i must make a near jackknife turn to get out of the parking area.. as the exit is always plowed in....as well as the fire hydrant, garbage dumpsters, and several concrete stair cases are either buried in the snow, or just barely visible. and ALWAYS iced over, since no sun melts anything during the daytime.
    again, i must know where my trailer is at all times.
    if you are not sure, get out and look (GOAL) several times if you have to.
    the accident you have, will be your fault.
    you should never really do any blind side moves, you set yourself up all wrong.
    you should have surveyed the situation BEFORE you even stepped back into your truck.
    this time, you got lucky.....next time......have your accident camera ready.
    al_huryn Thanks this.
