Take your foot off the clutch while driving!
Discussion in 'Questions From New Drivers' started by Ridgeline, Jun 3, 2023.
  1. Ridgeline
    22,636
    120,621
    I just spent a bunch of money on an issue with a truck over the past three weeks. The engine brake and cruise control was not working and the driver complained about it a lot, she went from an automatic to an 18 speed a month ago.
    The truck has been in a shop several times for this problem, and every time the shop could not find a thing wrong with it. They test drove the truck, they had one of the regional techs look at it and still no problems at all.
    The other day I rode with the driver to move another truck and trailer, I watched her carefully and it took me ten seconds to find the problem, she used the clutch pedal as a foot rest.
    Still can’t see how she thought this was comfortable, but it was a habit that she said this morning she is having real issues breaking.
    So please do not ride the clutch, your truck will thank you.
  3. Chinatown
    Chinatown Road Train Member
    76,959
    179,676
    Aug 28, 2011
    Henderson, NV & Orient
    I've seen men do that. Didn't look comfortable at all.
  4. A Bug
    A Bug Heavy Load Member
    919
    1,870
    Mar 15, 2014
    Sevierville TN
    I wish my company had a ten speed i could drive!
    Hatt91 and Suspect Zero Thank this.
  5. The Green Mountain
    The Green Mountain Light Load Member
    248
    2,095
    Nov 24, 2022
    Maine
    There's a little button with a spring down there that takes 20 minutes to change if it wears out. And if it wears out: no cruise; no Jake.
    Some folks ease the clutch to the point of the button where it kills the Jake to roll a hill thru residential parts. Being quiet.
    Some ride it cause they're moving quick 1, 2, 3, 4, 5, 6.... high side lag..... 7....... 8........
    But yeah - that's not a foot rest. Get off it when ya can.
    FerrissWheel Thanks this.
  6. The Green Mountain
    248
    2,095
    Nov 24, 2022
    Maine
    It's worse than having a wallet in your back pocket!
    Try the two'fer.
    okiedokie and Chinatown Thank this.
  7. D.Tibbitt
    153,289
    I'm not sure I would want a person like that driving a truck inthe first place
  8. MACK E-6
    49,735
    235,020
    We had an idiot once burn up a new clutch in 32K miles.
    He had an aversion to using low range. That doesn’t do them any favors either.
  9. Last Call
    Last Call Road Train Member
    7,568
    45,910
    Mar 15, 2021
    The only time your foot needs to be on that clutch pedal is when you are coming to a complete stop or starting from a dead stop or going from a forward gear to reverse.
    If you can't float the gears on a shift then you have no business driving a manual transmission..
    You should have a restriction on your CDL..
  10. Lazer
    Lazer Road Train Member
    1,830
    2,940
    Jan 22, 2017
    Without this discussion degrading into the ‘auto vs manual’ rabbit hole. Anybody that drives with their foot on the clutch, should not be in any truck period. If they were assigned an auto, they certainly will drive around with their foot on the brake.
  11. okiedokie
    okiedokie Road Train Member
    13,403
    104,575
    Jun 13, 2011
    PNWET
    What about resting your hand on the gear shift? Opinions?
