taking my 2nd general knowledge test
Discussion in 'Questions From New Drivers' started by 5280Dizzy, May 16, 2015.
  1. 5280Dizzy
    5280Dizzy Bobtail Member
    Just curious how many tests DMV have and how much do they differ? I missed 2 too many on the first and feel confident that I will pass this the 2nd time around if the test is similar to the first one. I've heard rumors the tests questions are the same but rearranged and some say they're all new questions. This is in Colorado BTW.
  3. tscottme
    tscottme Road Train Member
    This website has a few practice tests for each area that can be tested, such as General, Air Brakes, HazMat, etc.
    I found another website that seems to have many more tests in all of the areas.
    Try this link and search for the General, Combination, Air Brakes, etc that you are looking for. I used it to study for HazMat and Highly recommend it.
    http://www.truckercountry.com/cdl-practice-tests/
  4. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    I was told that the DMV uses a program for the tests that can randomize questions from an assortment of 500 different questions, this is in Alaska. I expect that many, if not most or all DMV's use the same program.
  5. Pungent Sauce
    Pungent Sauce Bobtail Member
    23
    27
    Mar 15, 2015
    Madison, WI
    I passed my CO test last month. There's a lot of good quizzes on the web, but honestly, if you can answer the questions in the CO CDL Handbook, you can pass the test.
    Leak down rates, following & braking distance. Get a grip on those and you're golden. Good luck!
