I use an app to balance the weight n usually get good mpg 7.7 fully loaded when empty tho is it best to have them slid all the way up or back? Also with heavier loads seems the further back i put them putting more on drives n steers the better any thought? Or a website that can help me max my mpg
tandem position for best mpg
Discussion in 'Questions From New Drivers' started by Keepitzenn, Feb 17, 2017.
And also does warmer weather improve mpg seems i get alot better in 60 degree plus vs 30 ill get 7.2 i pay for fuel so big dealto max my earnings
I keep between 500 - 1000 lb on my drives over the tandems. That's just me. Whether its right or wrong, I find the truck pulls easier. I find it just works better, pulls better, rides better. For me, it gets me better fuel mileage. The truck just isnt working as hard.
As for being empty, I slide mine all the way forward. Besides you can get in tighter places, intersections etc, cause its a shorter wheel base. You're not nearly as likely to drag the tandems through a ditch, off the end of a culvert, over a stop sign etc. For me, its a no brainer. Empty, slide 'em all the way forward. -
If you're pulling a van or reefer and the 5th wheel position, keeping the gap between the back of cab and nose of trailer as minimal as possible is always going to help improve fuel economy by keeping air turbulence to a minimum. Heavy or empty, makes no difference.
As far as the trailer tandems, I guess this depends on wether you have trailer skirts or not. If so, and if weight will allow, I'd imagine keeping them moved up closer to the rear of the skirt panels will help with MPG, but you have to position them where weight distribution will allow.
As far as temperature differences, with non-turbo gasoline engines, it's generally accepted they will get better MPG in hot temps versus cold temps, however I'm not sure if it makes so much different with today's charge-air cooler systems in high HP diesel engines. And based on past discussions on the matter, the matter will probably generate a lot of different attitudesLast edited: Feb 17, 2017
better to have more weight on your drives than on tandems, that way your not "pulling"the weight over hills if its on your drives, but im no expert.
Right, it's better for fuel consumption to "carry" the weight rather than "pull" it. Move tandem position wherever you need to keep the weight high on the drives.
It doesn't matter where the weight is, you are pulling it.
You might carry more on your drives or the tandems, but you are pulling the same weight. The engine does not know the difference - does it? -
Perhaps not. I personally prefer to have the bulk of the weight where I can control it though.
Ride is better with the weight on the drives. You can really tell when the trailer is tail heavy.
Rides rough AND pulls like a lead sled.cnsper Thanks this.
