Tank of Bad Fuel In Portage Wisconsin
Discussion in 'Truck Stops' started by Burky, Dec 16, 2007.
  1. Burky
    Burky Road Train Member
    Thursday evening, I was on my way to Morehead Mn with a load, and I stopped in at the Petro located on I-90 where it meets with I-39 in Portage Wisconsin. I pulled in my fine running truck, fueled, walked the dog, and then got back on the road, since I wanted to get on the other side of Minneapolis prior to stopping. About an hour and a half later, I noticed that everyone else seemed to be topping the hills just fine at abotu 60 mph, and I was chugging up them at 35!
    Looks like the fine folks at the Petro gave me a crapola load of fuel. I made it to the stop in Minneapolis, and shut down to spend the night. I decided in the morning that since it was relatively flat across Minnesota, I would continue on and get across the state before doing anything. I made it in, delivered on time, and then since I was empty, I headed back east. Truck ran weak, but with a little coaxing I could maintain 55, so rather than have work done out on the road, I headed home. I pulled in Sat morning to a shop that does work for us in Hodgkins Il, had the filter changed, and all is fine now.
    No fun quite like taking off in the morning and needing about 7 miles of running before you can get the truck up into 10th gear!!! Thanks Petro!!!
  3. myminpins
    myminpins Road Train Member
    1,578
    65
    Sep 20, 2007
    Dartmouth, NS, Canada
    Are you sure it was the fuel and not a clogged filter or something? If it was the fuel, you should contact Petro and get a refund. I find it hard to believe such a large truck stop could put out crappy fuel that had THAT much of an impact and you were the only one to notice. If they did that, surely lots of trucks would have noticed and you'd have heard about it on the news by now, don't you think?
  4. Burky
    Well, since the filter has been on the truck for about 4 weeks and it has been running fine, and it started to plug up within an hour and a half of picking up the fuel there, I would make the assumptio that the cause was the fuel that I picked up there. Granted I can't prove it with 100% certainty, and since I have subsequently refueled, whatever proof has been diluted, so to speak.
    I don't know if anyone else got the fuel, or if they simply changed their filters and went on their way. I could have gotten a shot of crud from the bottom of an almost empty fuel tank, or there could have been any number of things that caused it.
    But, my best guess is that the fuel from the Petro was bad, and is the source of the problem. Unless there is absolute certian proof, there is no recourse in a situation like this anyhow. You just make the best of it, put on a new filter, and go on your way.
    But I won;t be stopping there to fuel anymore. I can't be fooled twice.
  5. myminpins
    1,578
    65
    Sep 20, 2007
    We got bad fuel in our car once from an Irving. I didn't fuel at Irvings for years after that. There was water in the gas - you died - and it was winter and cold. NOT fun.
    Were your tanks really empty when you fueled? I've had the crud thing happen many times in our oil tank/furnace at home, that's all, so was just wondering.
    You could be absolutely right - there's just no way to tell. If you can fuel other places, I'd probably do it, too. I can't imagine having to crawl like that for hours and hours. Must have driven you nuts!!!
  6. Burky
    No, I still had about 50 gallons left in the tank when I fueled. I usually fuel somewhere in that range, and I knew if I fueled there, I could make it all the way to the destination and back without any need to stop unless I wanted to. I usually base my fueling times on scales ahead, my schedule, and some other things I factor in.
  7. Doma
    Doma Light Load Member
    171
    42
    Sep 19, 2007
    MA
    If it was the fuel from petro there would be allot of trucks out there with the same gripe, having said that it is not far from the norm for fuel to be tweaked but it usually comes from the refine,, I have had filters go bad after 3000 miles of being replaced, cheap filters are real crappy and sometimes the good ones are bad,, I am not saying the fuel was not bad but there would be many trucks in the area going bad, remember the pumps are fed by the tanks, so all the pumps would be spitting bad fuel, hmmm I havn't had new filters in a while and here it is snowing like a bandit outside my window, first stop tomorrow freightliner!
  8. Burky
    I assume that the filter was okay, since it was a factory Mack item. As I said, I can;t guarantee the problem came from there, but cause and effect seems to indicate that it did. Luckily, it's fixed now and I made it home with the load for tomorrow am.
  9. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    ULSD has a higher gel point for waxing than the old lsd did. Fuel filters seem to plug from fine to good with no warning.
    I change my filters about every 3-4 weeks. I also carry extras with me.
  10. Burky
    And while it did get cold in Minneapolis that night, the problem started down in the relatively warm, 30 degree weather in the middle of Wisconsin. And when I started the truck the following morning, it was a balmy 6 below, yet I encountered no issues with the fuel gelling at all. By the time I made my delivery, it had warmed up to 2 above in the Fargo area, so i remain convinced that the problem was with that particular fill up.
    it was a weird week for weather anyhow, with me having the windows down at 50 degrees on tuesday nite at Richmond In, and 2 nites later it's 6 below.
  11. 25(2)+2
    18,749
    45,409
    Sep 18, 2006
    the road less travelled
    I got a batch of bad fuel in MN, The truck started idling rough right away after putting 165 gallons into two 100 gallon tanks.
    The fuel filter looked like someone had dipped it in tar(it's an ISX). The mechanic thought it could have been some stale fuel somehow got into the tanks, but that place pumps lots of fuel. MN has Biodiesel regulation, but I had been buying it at other locations without problems. It had almost 20000 miles on the filter.
    It didn't shut the truck down, a faulty sensor on the coolant tank did that:biggrin_25510:.
