Tanker hose fitting storage
Discussion in 'Trucking Industry Regulations' started by Mainspring, Jun 19, 2010.
  1. Mainspring
    Mainspring Light Load Member
    52
    15
    Feb 25, 2009
    Does anyone know of any regulations, OSHA or otherwise, that prohibit the storage of dirty (including hazmat) fittings in the externally accessible compartment under the bunk in the sleeper?
    My thinking is that since that compartment is not sealed off from the rest of the sleeper by anything like an airtight seal, all of the fumes from the fittings (anyone who drives tankers knows how nasty those fittings are) will enter the sleeper. Most of our rigs have external storage compartments for these fittings, but some (specifically MY new-to-me tractor) do not. The stink in-and-of itself is bad enough, but I can't believe that the presence of oil/acid/corrosive/poison/whatever-that-greenish-purple-crap-is fumes in the sleeper isn't a violation of something somewhere.
    How can it be ok to run like that, but God forgive you have a stupid marker light out. :biggrin_25510:
    I know, I know...quit and get a different job or refuse to run like that. Well, when there are 25 guys waiting for this job...now...and every other job in the state, that's easier said than done.
    So, does anyone have any realistic thoughts?
  3. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    You've got to get them out of there. External storage is not that hard to get. Even having just a box welded under your trailer will work. I don't know of any regulations but I'm sure there's OSHA regs that would fit. We didn't have sleepers but we hauled almost 150,000 gallons a day with the truck and the cabs never smelled of gasoline.
  4. 3408
    3408 Light Load Member
    72
    10
    Oct 16, 2009
    Mesa, Az
    Fumes from the fittings are flammable and once the correct fuel to air mixture is achieved inside your cab all you need is a spark to kiss your Harry behind goodbye.
    Plus the fumes are intoxicating and there are laws ..............
    Get those fittings out of your truck now if not sooner.
  5. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    I believe the DOT regs do prohibit carrying any HazMat material in the cab, and the storage area is part of the cab. I can't cite the chapter, but I remember reading it when I was studying for the DOT test.
    As others have said, get them out, now...I would hang some chains off the trailer frame and pvc tubing to hold them if needed. Or hang it off the back of the sleeper, if it needs to be on the truck. Just loop a chain through them all, or a bungee cord and tie to the back of the truck.
  6. Powder Joints
    7,939
    8,277
    Sep 25, 2007
    Rosamond, SoCal
    I have never seen Cal-OSHA or Msha ever even mentioning this. Common sense still applies, All the trailers (bulk tankers) have storage compartments under the A trailer, also an area in the front of the A trailer.
    I only carry new unused fitting under the bunk, and tools... From what Ive seen we do not need desk dwellers to tell us not to put harmful items under our bunks. ( except for the sheep dropping, because we can't gamble on someone see them)
  7. MO family man
    MO family man Heavy Load Member
    814
    242
    Oct 31, 2007
    Nunya, MO
    Hang them on the back then hope they are there in the morning?
    I actually keep mine in a bucket under the bunk, course I actually make a point to rinse them as best I can before I leave. Think about it, the trace amounts on an unrinsed fitting can't be much more than the trace amounts in the tread of your rubber boots. What about your gloves? Did you rinse them but not your fittings?
    The only thing that I find really objectionable to have under the bunk is SBS or any sulfur based product for that matter. Seems after messing with that stuff I can almost taste it for the rest of the day.
    My truck has the external box but I prefer to keep extra oil and antifreeze in there because ya just ain't lived till an oil jug ruptures in the side box:biggrin_25510:. Oh and propane bottles definetly are going in the outside box.
  8. Powder Joints
    7,939
    8,277
    Sep 25, 2007
    Rosamond, SoCal
    I get in a real good mood when the Nox leaks.... Sorry for the changes, just could not resist.
    phroziac Thanks this.
  9. Powder Joints
    7,939
    8,277
    Sep 25, 2007
    Rosamond, SoCal
    Tell or ask your company for a storage box, a couple of milk crate behind the cab.
  10. Mainspring
    52
    15
    Feb 25, 2009
    No such storage areas on our 5k-7k gallon trailers. Besides, we might pull 2 or 3 different trailers in a day.
    The best solution is a storage box on the tractor, but we're lucky to have tires on our trucks.
  11. Powder Joints
    7,939
    8,277
    Sep 25, 2007
    Rosamond, SoCal
    Opp's wrong twice in the same day... Yeah I our sulphur tractors carry there used stuff in a box that mounts between the frame rails.
