Tankers and ice
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Salted, Nov 28, 2014.
  1. Salted
    Salted Light Load Member
    96
    22
    May 23, 2014
    What is the best way to get around the top of your tanker when its covered by ice? I'd you don't have a torch?
  3. Chinatown
    Chinatown Road Train Member
    74,885
    170,631
    Aug 28, 2011
    Henderson, NV & Orient
    Wear golf shoes....lol.
    Dr_Fandango44 Thanks this.
  4. Salted
    96
    22
    May 23, 2014
    I did see slip on round tip spikes
  5. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    Don't, if possible. When I have to, I wear my boots, and make sure I have a good footing on the catwalk before shifting my weight. If you're talking about a dry bulk with no catwalks, then good luck to you, your guess is as good as mine.
  6. Salted
    96
    22
    May 23, 2014
    With the bulks we usually have the drop down gates at the loading zones or we load feom the side pipe. But on our sludge tanks we have a 6" lip all around the top with 2 drains in the rear but it dont help much. I was thinking maybe throwing cat liter when i walk on it
  7. wore out
    wore out Numbered Classic
    15,926
    192,756
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What about carrying a big container of Morton table salt in your jacket with the pour out spout. Sprinkle it out as you walk. It provides traction as well as melts it. Its an ol bullhaulers trick, it may work for you to.
  8. Stormdriven
    Stormdriven Medium Load Member
    331
    217
    Mar 11, 2014
    south, central, US.
    I observed a ladder strapped to the hose-rack of a bulk Truck recently.
  9. Salted
    96
    22
    May 23, 2014
    I think ill give that a try tomorrow
    wore out Thanks this.
  10. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    This is what I use!
  11. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    I normally bang on the Cat walks with my hammer or spanner wrench to knock the ice off. If its snow sweep them first. I haven't had many problems actually. If there is a whole bunch of freezing rain solid ice up there that can't be knocked off I am probably not running anyway.
