Tapping into oil pressure system
Discussion in 'International Forum' started by kubasj05, Sep 15, 2019.
  1. kubasj05
    kubasj05 Light Load Member
    148
    57
    Apr 18, 2013
    Hi everyone, I am about to do manual oil pressure check. Where would be the best spot to hook up the oil pressure Guage on 2012 Maxxforce 13.
  3. Snow Monster
    Snow Monster Medium Load Member
    543
    1,297
    Feb 9, 2019
    Find the oil sensor on the engine, remove it and tap in there.
    Will tell you how accurate your gauge is, where if you tap in somewhere else it may be out a couple pounds one way or another from the oil sensor hole.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Easiest way is to remove oil pressure sensor and install the test fitting. Oil Pressure Test Fitting tool number is, 12-889-02.
    2013Maxx Thanks this.
  5. maneri1891
    maneri1891 Bobtail Member
    31
    Jun 30, 2019
    Do we need that tool to remove and install the oil pressure sensor?
  6. Heavyd
    7,826
    6,276
    Feb 4, 2009
    No, standard tools.
  7. Armond96
    Armond96 Bobtail Member
    @Heavyd If I remove the oil pressure sensor to Put a manual gauge on, how can I stop the truck from shutting off due to no pressure?
  8. AModelCat
    164,624
    Why not just use a tee fitting? Put the pressure sensor in one port and the test gauge in the other?
    Deere hunter Thanks this.
  9. Armond96
    I was actually trying to google one but I’m not entirely sure of the size of fittings and stuff needed
    2016 n13 645k miles
    Deleted (not sure if a tune could be throwing the ecm off)
    for context my truck has an issue with oil pressure under load and high temperature
    I’ve replaced my entire oil cooler module with the crank case breather oil cooler etc
    My pressures by gauge are as follows
    before module
    Cold Start idle 40 psi
    Cold rev 48-50 psi
    Bobtailing 1500rpm 40 psi
    Heat soaked 1500 rpm 28-40 psi
    Hot idle 8-15 psi
    after module
    Cold start idle 40 psi
    Cold rev 60-70 psi
    all Other pressures are the same as before the module change
    the truck doesn’t knock (I may have heard a knock one time before it shut off but it could be my paranoia)
    or do anything else abnormal it logs code spn 100 fmi 18 religiously over 50 counts last time I checked the codes via dashboard
    other things I’ve done
    Checked the voltage the sensor was putting our by back probing the wires
    this was in tune with what the ecm is seeing
    other random things that may be related the truck is pretty wacky with all of the gauges that I believe are ran through the canbus/ecu
    fuel gauge jumps around
    Speedo jumps around
    Coolant temperature never goes above 140 degrees unless I’m in a hill pull with weight Jpro matches all figures the cluster is showing me
    (I’ve changed out coolant sensor for a new one and jumped the two pins together which pegged the coolant gauge to hot)
    voltage gauge
    Air pressure gauges
    Rpm are all accurate and stable
    so with all that being said it’s strange that the oil cooler module would only have an effect on cold start revving.
    also I can recreate any of the pressures I listed above which tells me it’s pretty consistent
  10. Heavyd
    7,826
    6,276
    Feb 4, 2009
    We leave the sensor unplugged and reprogram it for warning only.
  11. Armond96
    @Heavyd hey I haven’t been able to test the oil pressure yet but I do have a question
    My multimeter is showing 20-30v on the ect and the eop negative wires when grounding them to the engine block
    however it shows .2-.3 volts when grounding the negative wires back to the battery.
    can you make any sense of this ? Chat gpt thinks I either have a bad sensor back feeding the ecm or a bad internal ground in the ecm
    also not sure if I stated this before but it will sometimes go on a frenzy popping the 5amp ecu fuse on the dashboard
    like it’ll pop it 6 times in an hour and then not pop it for weeks
