Tarp Question
Discussion in 'Ask An Owner Operator' started by BigBadBill, Aug 27, 2011.
  1. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    I have a load from Dow of insulation and it was loaded pushed up into the bulk head. I can’t get the front sealed off tight enough to keep the air out. Ballooning is not bad and not doing damage but what suggestions do you have to stop this on future loads.
  3. Diesel Dave
    9,319
    30,006
    Jan 20, 2010
    Hesperia, Ca.
    Get rid of the bulk head. I dont like it cause when I need to over hang in the front I cant due to the bulk head.
    BigBadBill Thanks this.
  4. sixpackbill
    sixpackbill Light Load Member
    114
    29
    Oct 6, 2010
    hamilton on.
    tarp the head board like its part of the load,thats what i do
    BigBadBill and aggie1978 Thank this.
  5. aggie1978
    aggie1978 Light Load Member
    165
    85
    Mar 16, 2008
    Jackson, MI
    this would be the best thing to do
  6. BigBadBill
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Yeah, I was thinking that but need to look at my options for for chains and binders. My tractor is alread to heavy for this and don't want to put a rack on it and move more weight forward. I have a crappy tool box I was thinking of creating a way to hang the chains in and getting adding another larger box.
    But with what I have do you have any suggestions?
    Was also going to PM you on tips on how you use the "rope" rather than bungees. Guy loading at the same place yesterday was doing it but was all p issy with me when he saw I was getting $.75/mile than he was from same broker. Like that is my fault.
    But he was tarped in half the time of the rest of us and it was tight. Just couldn't get a good look at what he did.
  7. BigBadBill
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    That could work. Couple sharp spots in front of board kept me from doing that this time. Guess I will get the grinder out next time I'm home and fix those. And if before then will tape them off.
  8. Diesel Dave
    9,319
    30,006
    Jan 20, 2010
    Hesperia, Ca.
    I have a box that sits in between the frame(tractor) and have all my chain's in there.
  9. nuts&bolts123
    nuts&bolts123 Light Load Member
    119
    51
    Aug 16, 2011
    bensalem pa
    i agree with six pack tarp the head board also.
    next time dont let them push it all the way up. you only need about 2 incches space. or put the tarp flipped over the head board before they load you
  10. nuts&bolts123
    119
    51
    Aug 16, 2011
    bensalem pa
    plus straps work better some times than chains depending on your load. u can strap over the tarp. if its ballooning
    bamanation Thanks this.
  11. BigBadBill
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Asked them not to push forward but because I was already going to hang over the rear they wouldn't do it. Learning as I go.
    Was going to fix it right now despite less than 250 miles to go but with step on the board I would have to slide the tarp forward a couple inches to make work. AND that is not going to happen on this load.
    Live and learn.
